B-field from a current in a wire above a conducting surface
The discussion centers on understanding the magnetic field generated by an infinite current wire positioned above a neutral, conducting surface. The initial thought was to apply imaging techniques, typically used in electrostatics, to analyze the magnetic field behavior. It is noted that adding a current in the opposite direction does not lead to cancellation of fields at the surface. The key equation for the magnetic field around a wire is provided, emphasizing the circumferential nature of the field. The conclusion suggests that imaging techniques can be effectively utilized for this scenario.
Sidsid
What is qualitatively the difference between the magnetic field of an infinite current wire and one with the addition of an infinite , neutral, conducting surface under it. Find it for points between them,under the surface, and above the wire. The magnetic field is 0 at the conductor.
B= (mu_0* I)/(2pi r) (circumferential)
I first thought of imaging techniques, because the setup reminded me of it, but i have only ever seen those of electrostatics. If i for example add a current in the opposite direction and with the opposite heigth of the surface the fields dont cancel out at the surface, i think. What is the best approach?
Sidsid said:
Homework Statement: What is qualitatively the difference between the magnetic field of an infinite current wire and one with the addition of an infinite , neutral, conducting surface under it. Find it for points between them,under the surface, and above the wire. The magnetic field is 0 at the conductor.
Relevant Equations: B= (mu_0* I)/(2pi r) (circumferential)
I first thought of imaging techniques, because the setup reminded me of it, but i have only ever seen those of electrostatics. If i for example add a current in the opposite direction and with the opposite height of the surface the fields don't cancel out at the surface, i think. What is the best approach?
Yes. Use imaging techniques.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
