peroAlex
- 35
- 4
I came across a pretty interesting question that asks for magnetic flux density (B-field) on the axis of the equilateral triangle. This axis is meant to be perpendicular to triangle's surface passing through its centroid. Assuming that a triangle has sides denoted ##a## and conducts current ##I##.
Law of Biot-Savart: ## dB = \frac{\mu_0 I}{4 \pi} \frac{dl \times R}{R^3} ##.
B-field of a line segment: ## B = \frac{\mu_0 I}{4 \pi \rho} (\cos(\alpha_1) - \cos{\alpha_2}) ##
I managed to compute B-field at triangle's centroid. Since ## h = \frac{a \sqrt{3}}{2} ## and distance from a side to centroid is ## \frac{h}{3} ##, I managed to derive (for one side) $$ B_1 = \frac{\mu_0 I}{4 \pi \frac{\frac{a \sqrt{3}}{2}}{3}} (\cos{30} - \cos{150}) = ... = \frac{3 \mu_0 I}{2 \pi a}$$ so for all three sides combined the result is simply three times higher value: ## B_T = 3 B_1 = \frac{9 \mu_0 I}{2 \pi a}##.
But this is where I'm stuck. I don't know how to derive for axis of triangle, but I did manage to pull out correct result which should be ## \frac{ 3 \mu_0 I a^2 }{ 8 \pi \sqrt{3z^2 + a^2} (z^2 + \frac{a^2}{12}) } ##. Can somebody please help me with this one or at least point me on the correct path?
By the way, I hope you're having a fantastic Tuesday!
