BA or BS in physics for future engineer?
In summary, the difference between BA and BS in physics is that the BA option requires fewer physics classes and allows for more time to take engineering classes. However, it may not be as marketable or prepare students as well for engineering graduate school. The BS option is more rigorous and may be preferred for future engineers, but it could also lead to a longer time in school. Ultimately, the courses taken and experience gained are more important than the name of the degree.
Nevill24
Whats the big difference between BA/BS?? Right now I am doing the BS in physics in my sophomore year. Here at my school you are required to have an "emphasis" area in the physics programs. I am hoping to do some type of engineering (Mechanical is prefered, though i hear the only one that works well in the program is environmental and you can actually get a minor in it here) but it really seems like I would be craming in a lot of tough classes for this. Right now I am considering the environmental b/c of how it fits into the program, but would the minor in it really help land a job??
The BA option you are not required to take as many physics classes so i would have more time for engineering. But is a BA just as marketable as a BS, are the salaries any different, etc? I would just switch to engineering but I've switched majors a few times already so I am actually a year behind for a bachelors degree and a 6th year would be too expensive. FWIW I switched from chemistry to physics so I've actually taken enough chem classes for a minor in chem as well.
Also I've heard you can get into grad school for engineering w/ a BS in physics...anyone know much about this? Can you get into grad school w/ a BA??
Where both are offered, generally the BA is less rigorous. You'd be better served to look at the actual requirements.
You can get into grad school with just about anything, but you're going to be expected to master the same material no matter what you come in with. Less preparation now = more catch-up later.
For a future engineer, an engineering degree would probably serve you better. Most places, it's hard to get a PE license without one.
I figure if i want to get a engineering job I am going to have to go to grad school for some type of engineering. The only reason I am going with physics instead of engineering for a bachelor is because of time/money. I can graduate w/ physics in 2 years but it will take 3 years for engineering cause I am so far behind there.
But if I am not going into physics grad school then a BA should be fine then?? The only physics classes i wouldn't take compared to the BS would be electrodyanmics II, quantum II, Experimental physics II, Thermodynamics and Stat. Mech (I have taken physical chem=thermo) and Physics Research. I don't think these courses would really effect me going into eng grad school. I am just worried the BA won't "look" as good to employers or i may have trouble gettin into grad school (though a plus would be i would have more time to take undergrad eng courses). But then if you have a MS or PhD the bachelor degree probably doesn't matter that much i would think??
Depending on which engineering discipline you go into, the lack of thermo could be a problem. The BA may not be an issue at all, but the BS is safer.
But, more importantly, if you want to be an engineer, you have 3 years of school to do that via the engineering major. That gives you the standard professional degree and you never have to worry.
The other route require 2 years to get the BA/BS in Physics, followed by 2 more years (maybe 1.5 years) for an MS and you might have to worry.
In other words, the straight engineering major is shorter and safer. If that's what you want to do, go that route.
In order of preference, you should be considering
  1. B.S. in mechanical engineering: If this is what you want to do, then there's no point in putting it off until graduate school. This is also the track that will best prepare you to work as a mechanical engineer.
  2. B.S. in physics: If for whatever reason you decide to put off actually learning what you want to do, this is the next best thing. A B.S. in physics will give you a solid technical foundation that will give you a good shot at admission into almost any sort of engineering graduate program.
  3. B.A. in physics: Danger Will Robinson! The courses you mention as not being required for the B.A. are some of the central course for physics. Without Electromagnetism II, you might not even get to electromagnetic waves. Without Quantum II, you might not get to the hydrogen atom or spin. And if you're serious about engineering, you should be getting all the hands-on (i.e. experimental) experience that you can get. This is especially true if you're considering mechanical engineering, as machine shop courses are a fundamental part of every undergraduate program in mechanical engineering. With just a B.A. in physics, not only might you have trouble getting into graduate school--you might find yourself underprepared once you get there.
I don't really understand why people say a B.A. is less rigorous. Yea, they require less classes, but it isn't like you CANNOT take those classes. Every school tends to define their B.A.slightly different, but overall, in a B.A. the difference in hours are made up with a language. A B.A. is a wonderful route to go if you want to learn a language and still do science. Hell, you can take your language requirement during the summer and take extra courses during the school year. It really is what you make it to be.
I got a B.A. in mathematics and I managed into get into a fairly top rated graduate school.
What matters is the actual courses that you take, not the name of your degree. In a previous thread on this topic, I think someone mentioned that at least one of the "big name" schools (Harvard?) offers "only" a BA in physics. Who in his right mind would turn up his nose at it? :rolleyes:
Where I teach, the only difference between a BA and a BS is that science/math departments give BS's, whereas humanities departments give BA's. Exception: the psychology department gives both BA's and BS's, with identical requirements! Psych majors simply pick which one they want on their diploma.
Once upon a time, our BA's had to take a foreign language but didn't have to take any math. Our BS's had to take math, but didn't have to take a foreign language. Now all students have to take both, for their general education requirements.
well looking back over the BA program, so your not required to take those classes i mentioned earlyer (btw i meant E&M II rather than statics II) but you are required to take 2 additional physics courses 300+ level so i would not be missing out on as many physics courses as i said earlyer (and actually i choose which courses so it could be more interesting). You are required to take 4 semester of foreign language though which kinda sucks, but the BA definitely opens up room for a minor or emphasis.
I could still do BS in physics and get the minor/emphasis in engineering but the workload would def be considerably tougher.
if i take the physics route I am lookin at probably: BS/BA in phyics, minor in chem, minor/emphasis in either environmental or mechanical eng. This will take 2 years. Not sure how easy it would be to get a job with all this though. So maybe grad school?
Eng: it will take 3 years so more money (i run out of life scholarship next year so id go 2 additional years without 7.5k a year scholarship)
I really don't mind going to grad school as long as its obviously somethin i will enjoy learning more about. And I hear most grad schools have really good fellowships and assitantships.
But I really can't make up my mind. I am probably going to go talk to an advisor this week and hopefully they can help me out with it all. Thanks for the comments so far.
I am curious as to why you have this assumption. Most engineering jobs simply require a B.S. degree. Some companies may even pay for you to get an M.S., which certainly negates the extra cost of a year of undergraduate education. Also, since you can "easily" get a job with a B.S., you would start making money right away instead of spending more time in graduate school. If you know you want to do engineering later, just do it now.
If i took the bachelor physics path then i assume to get a engineering job i would need a grad degree in engineering. I have heard of B.S physicist doing engineering but i image it would be a lot more difficult since you are competing against people that actually do have a eng degree.
It seems like most of the advice leans toward switching over to eng major but the idea/cost of 6 years of undergrad is, I guess, a lot more difficult than it sounds.
Disregarding issues related to becoming a licensed engineer (for which you usually need an engineering degree) and getting employment as an engineer (for which you usually need an engineering degree):
The engineering degrees have had quite a lot of work go into determining their curriculum. The accreditation process is actually fairly strict since they have to make sure it counts not just towards the department's graduation requirements, and the university's graduation requirements - but also satisfies rules laid down by the certifying body (that's asserting you know enough basic engineering to be trusted with things that can kill people if they break) as well as state and federal laws that are also trying to keep undertrained engineers from creating a public safety hazard.
If you want to work as an engineer, and aren't planning on taking a research-oriented career path (for which you would need *at least* a masters, preferably a Ph.D.), find a way to get the engineering degree. Dealing with funding sucks, but there are tons of scholarships and state/federal grants for engineering fields.
Danger Will Robinson LOL!
Related to BA or BS in physics for future engineer?
What is the difference between a BA and BS in physics for future engineers?
A BA in physics typically focuses more on the theoretical and conceptual aspects of physics, while a BS in physics delves deeper into the quantitative and mathematical aspects. For future engineers, a BS in physics may be more beneficial as it provides a stronger foundation in mathematics and problem-solving skills.
Can I become an engineer with a BA in physics?
Yes, it is possible to become an engineer with a BA in physics. However, you may need to take additional courses or gain practical experience to supplement your physics knowledge and skills. It is important to research the specific requirements for engineering programs and careers you are interested in pursuing.
Which degree is more suitable for a career in engineering?
Both a BA and BS in physics can lead to a career in engineering. However, a BS in physics may be more advantageous as it provides a stronger foundation in quantitative and problem-solving skills that are essential for engineering. Some engineering programs may also prefer or require a BS in physics.
What courses are typically included in a BA or BS in physics for future engineers?
Courses in a BA or BS in physics for future engineers often include mechanics, electromagnetism, thermodynamics, quantum mechanics, and mathematical methods for physics. The difference between the two degrees may be the level of depth and focus on theory versus application in these courses.
Which degree is more beneficial for graduate studies in engineering?
Both a BA and BS in physics can prepare students for graduate studies in engineering, but a BS may be more advantageous. Graduate programs in engineering often require a strong foundation in mathematics and physics, and a BS in physics can provide that. However, it is important to research the specific requirements of the graduate programs you are interested in to determine which degree may be more suitable.
