Back Correcting the Uncertaininty Principle?
  • Thread starter Thread starter bstacey
    Principle
bstacey
I'm sort of new to quantum mechanics and was wondering that when we use a photon (light) to measure a particle for its velocity (momentum) with varying wavelenghts depending on the accuracy we want, why can't we back correct to take into consideration the wavelength of the photon when finding out the probability of the position? Hence making it's position more accurate or even exact?
Because you can't. Using a longer wavelenght means having a not very focused image of a point: you see a disk instead of a point and the disk diameter increases with wavelenght.
Well what if a shorter wavelegh was used to measure the position? Would this effect the momentum? And can't this be taken into account when predicting it and then back corecting?
What do you mean by "taking into consideration the wavelength". All you can do with wave length is say "the particle is within one wavelength of the measured position". The smaller the wavelength, the more accurate the measure of position, but knowing the wavelength doesn't allow us to say more than that.
And every time you "hit" a particle with a photon to measure its position, you change its momentum and so its speed. The lower the wavelength, in order to get a more accurate position, the greater the energy of the photon so the greater change in momentum.
I am not sure if this falls under classical physics or quantum physics or somewhere else (so feel free to put it in the right section), but is there any micro state of the universe one can think of which if evolved under the current laws of nature, inevitably results in outcomes such as a table levitating? That example is just a random one I decided to choose but I'm really asking about any event that would seem like a "miracle" to the ordinary person (i.e. any event that doesn't seem to...
