Balancing a complex Chemical equation
In summary, the conversation is discussing how to balance a redox reaction involving C6H5OCl, NO3-, N2, Cl-, CO2, H+, and H2O. The suggested methods for balancing the equation include using half reactions, oxidation numbers, or an algebraic approach. It is mentioned that NO3- may come from nitric acid, and H+ may come from the dissociation of nitric acid. The conversation concludes with the suggestion to use HNO3 as a reactant and HCl as a product to balance the equation.
CoinToss
Balance the following Chemistry equation, you are allowed to add H{+} and H2O where needed
Given
C6H5OCl + NO3- --> N2 + Cl- + CO2
2. The attempt at a solution
Balance the carbon first:
C6H5OCl + NO3- --> N2 + Cl- + 6CO2
Increase Oxygen O in NO3{-} to compensate; also increase N on RHS
C6H5OCl + 4NO3- --> 2N2 + Cl- + 6CO2
Bring out the H{+} and O{2-} on RHS
C6H5OCl + 4NO3- --> 2N2 + Cl- + 6CO2 + H2O + 3H+
Multiply both sides by 2
2C6H5OCl + 8NO3- --> 4N2 + 2Cl- + 12CO2 + 2H2O + 6H+
Compensate for 6H{+} on RHS by increasing NO3 by 1 to form H2O on RHS
2C6H5OCl + 9NO3- --> 4N2 + 2Cl- + 12CO2 + 5H2O + N3-
At this point I would assume that H{+} Is required on the LHS to give N2 and H2O on RHS
2C6H5OCl + 10NO3- + 2H+ --> 5N2 + 2Cl- + 12CO2 + 6H2O
Which is looking pretty good so far-- except the charges on either side are not balanced. And this would be the point where I am stuck. Was there supposed to be a different approach to this? I appreciate your time. Thank you.
This is a redox reaction and these are usually difficult to balance by inspection. Try either one of the redox methods (half reactions or oxidation numbers), or use algebraic approach. All these are described here: balancing and stoichiometry.
Perhaps the NO3 radical comes from an acid which is added to the other organic compound.
Excellent, I think this would be very helpful. Thank you very much.
@SteamKing: HNO3 could very well be the said acid but I gather that it isn't of much interest at the moment?
NO3- is not a radical, just an ion, product of the nitric acid dissociation.
And maybe some of the H+ ions come from said nitric acid dissociation?
Yes. And it is also possible to balance the reaction using HNO3 as a reactant and HCl as a product.
Related to Balancing a complex Chemical equation
1. What is a chemical equation?
A chemical equation is a representation of a chemical reaction using chemical formulas and symbols to show the reactants and products involved.
2. Why is balancing a chemical equation important?
Balancing a chemical equation ensures that the law of conservation of mass is followed, meaning that the number of atoms of each element in the reactants is equal to the number of atoms of that element in the products.
3. How do you balance a chemical equation?
To balance a chemical equation, you need to adjust the coefficients in front of each compound or element until there is an equal number of atoms of each element on both sides of the equation.
4. What are some tips for balancing complex chemical equations?
Some tips for balancing complex chemical equations include starting with the most complex molecule and balancing the atoms of elements that appear only once on each side of the equation first, and then moving on to the more common elements.
5. Can a chemical equation be considered balanced if it has the same number of atoms on both sides?
No, a chemical equation can only be considered balanced if it has the same number of atoms of each element on both sides and follows the law of conservation of mass.
12K
28K
11K
