Balancing Oxidation-Reduction Reaction
  • Thread starter Dove99x
  • Tags
    Reaction
In summary, the conversation discusses the rules for balancing equations and identifying the oxidizing and reducing agents. An element that is reduced gains electrons and loses oxygen, while an element that is oxidized loses electrons and gains oxygen. The correct answer for the given equations is also provided.
Dove99x
1. Complete and balance the following equations, and identify the oxidizing and reducing agents:
2. Rules.
1) an element that is reduced Gains electrons and loses Oxygen
2) an element that is oxidized loses electrons but gains Oxygen
3. My attempt
Oxidizing Agent: 5e + 8H + MnO4 ^(1-) ---> Mn ^(2+) + 4H2O
Reducing Agent: 2H2O + CH4O ---> H2CO2 + 6H ^(1+) + 6e
At this point I relize that what I'm doing is totally wrong. I don't know how to solve this.
4. Correct Answer from Book:
4MnO4 ^(1-) + 5 CH3OH + 12 H ^(1+) ---> 4Mn ^(2+) + 5HCO2H + 12 H2O
Correct.
Oxygen is not balanced.
FAQ: Balancing Oxidation-Reduction Reaction
What is an oxidation-reduction (redox) reaction?
An oxidation-reduction reaction is a type of chemical reaction in which electrons are transferred between reactants. The reactant that loses electrons is oxidized, while the reactant that gains electrons is reduced. This transfer of electrons results in a change in the oxidation states of the elements involved.
How do you balance a redox reaction?
To balance a redox reaction, the number of atoms of each element must be equal on both sides of the equation. This is achieved by adding coefficients (numbers in front of the reactants or products) to the chemical equation. First, balance the atoms that are not involved in the redox reaction. Then, balance the atoms that change oxidation states (i.e. those involved in the redox reaction) by adding electrons to one side of the equation. Finally, balance the charges by adding H+ or OH- ions, depending on whether the reaction is acidic or basic.
What is the difference between an acidic and basic redox reaction?
In an acidic redox reaction, hydrogen ions (H+) are present in the reaction. These ions can act as reactants or products, and must be balanced in the overall equation. In a basic redox reaction, hydroxide ions (OH-) are present, and they must also be balanced in the overall equation. Depending on the reaction conditions, different methods may be used to balance a redox reaction.
What is the purpose of balancing a redox reaction?
The purpose of balancing a redox reaction is to accurately represent the reactants and products involved in the reaction. A balanced equation shows the correct stoichiometric relationship between the reactants and products, and allows for the calculation of quantities of substances involved in the reaction. It also follows the law of conservation of mass, which states that matter cannot be created or destroyed in a chemical reaction.
What are some common strategies for balancing redox reactions?
Some common strategies for balancing redox reactions include the half-reaction method, the oxidation number method, and the ion-electron method. The half-reaction method involves balancing the oxidation and reduction half-reactions separately, and then combining them to form the balanced overall equation. The oxidation number method involves assigning oxidation numbers to each element in the reaction and using these numbers to balance the equation. The ion-electron method involves balancing the charges on each side of the equation by adding or subtracting electrons.
