Balancing torques, static equalibrium
In summary, the question is asking to find the tension in a supporting string for a uniform rod attached to a vertical wall and ceiling. The solution involves balancing torques and considering the upward torque provided by the tension. The tension is equal to half the weight of the rod.
Bu2009
A uniform rod of mass M sticks out from a vertical wall and points toward teh floor. If the smaller angle it makes with the wall is theta, and its far end is attached to teh ceiling by a string parallel to the wall, find the tension in the supporting string.
ok I know that this involves balancing torques and the object is in static equalibrium.
this is a MCAt style question so I'm giving multiple choice answers, I know the answer to the question, but I wasn't sure how it was derived.
I know that my downward torque based on the rod is (L/2)Mg sin theta. since net torque is 0, the CCW torque must balance the CW torque, but how does this make T = mg/2?
Hi BU2009 and welcome to PF,
Your downward torque is correct. Now consider your upward torque, provided by the tension. At what [perpendicular] distance does this tension act from the pivot (wall)?
To find the tension in the supporting string, we need to consider the forces acting on the rod in static equilibrium. The force of gravity (mg) acts downward on the rod at its center of mass, while the tension force (T) acts upward at the point where the string is attached to the ceiling. Since the rod is in static equilibrium, the net force on the rod must be zero. This means that the upward tension force must balance the downward force of gravity.
To find the value of T, we can use the concept of balancing torques. The torque of a force is the product of the force and the distance from the point of rotation. In this case, we can choose any point as the axis of rotation, but it is most convenient to choose the point where the string is attached to the ceiling.
The torque due to the weight of the rod is (L/2)Mg sin(theta), as you correctly identified. To balance this torque, we need an equal and opposite torque in the counterclockwise direction. This torque is provided by the tension force, and its magnitude is T(L/2)sin(theta). Setting these two torques equal to each other, we get:
(L/2)Mg sin(theta) = T(L/2)sin(theta)
Solving for T, we get:
T = (L/2)Mg sin(theta) / (L/2)sin(theta) = Mg/2
Therefore, the tension in the supporting string is Mg/2. This makes intuitive sense, as the weight of the rod is evenly distributed along its length, so the tension force must also be evenly distributed to balance it. I hope this explanation helps you understand how the tension in the string is derived using the concept of balancing torques.
FAQ: Balancing torques, static equalibrium
What is a torque?
A torque is a type of force that causes an object to rotate around an axis or pivot point. It is often measured in units of Newton-meters (N*m) or foot-pounds (ft-lb).
How are torques balanced in static equilibrium?
Torques are balanced in static equilibrium when the sum of all clockwise torques is equal to the sum of all counterclockwise torques. This ensures that the object is not rotating and is in a stable, balanced position.
What factors affect the magnitude of a torque?
The magnitude of a torque is affected by the distance from the axis of rotation to the point of application of the force (known as the lever arm) and the magnitude of the force itself. The direction of the force also plays a role in determining the direction of the resulting torque.
How do you calculate the net torque on an object?
To calculate the net torque on an object, you must first identify all the forces acting on the object and their respective lever arms. Then, you can use the equation τ = r x F, where τ is the torque, r is the lever arm, and F is the force. The direction of the torque will depend on the direction of the force and the direction of rotation.
What is the difference between static and dynamic equilibrium?
Static equilibrium refers to a state where an object is at rest and not moving or rotating. Dynamic equilibrium, on the other hand, is a state where an object is in motion but not accelerating or changing its direction. In both cases, the net force and net torque acting on the object are equal to zero.
