Ball bearing launched from point
To find the initial velocity of a ball bearing launched horizontally from a height of 85.4 cm, the average distance traveled was recorded as 250.24 cm. The calculation involves using the equations of motion, specifically d = vt for horizontal distance and h = 0.5at² for vertical drop. The derived formula v = d sqrt(g / 2h) was confirmed to yield the same result as using the standard horizontal and vertical motion equations. The calculated initial velocity was approximately 5.99 m/s. Understanding these principles allows for calculating both the initial velocity and the distance traveled even without a provided distance.
colerelm1
In my physics class we shot a ball bearing horizontally 85.4cm off the ground and we recorded the distance at which it landed. How can I find the initial velocity? The average distance traveled was 250.24 cm.
What if I was not provided I distance, how could I calculate the distance this ball would travel?
I'm not sure.
I have tried doing:
d sqrt(g / 2h)
2.5024(converted to m) sqrt( -9.8 / 2 x -85.4)
= 5.99 m/s
Is this right?
I don't recognize the formula d sqrt(g / 2h) but I get the same answer when I do it with good old horizontal (d=vt) and vertical (d = .5at²) parts.
They're the same:
(1) d = vt
(2) t = \frac{d}{v}
(3) h = \frac{a}{2}t^2
substitute t from equation (2) above:
(4) h = \frac{a}{2} \left(\frac{d}{v} \right)^2 = \frac{ad^2}{2v^2}
(5) v^2 = \frac{ad^2}{2h} = d^2 \left( \frac{a}{2h} \right)
(6) v = \sqrt{d^2 \left( \frac{a}{2h} \right)} = d \sqrt{\frac{a}{2h}}
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up ##Mg \sin \theta ## will act downwards and maximum static friction will act downwards ## \mu Mg \cos \theta ## Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
