Ball collides with an inclined plane
In summary, the ball falls from a height of h and collides with a frictionless inclined plane at an angle of 45 degrees. The ball bounces off the plane at p1 and then collides again with the plane at p2. I think the ball bounce off the plane at p1 in such a way that the velocity is parallel to the horizontal, but this is based on the diagram. So if someone could confirm this, that would be much help.
hannibalisfun
A ball mass m falls from height h and collides elastically with a frictionless inclined plane; the plane is a 45 degree angle with the horizontal. The first spot it collides with is p1 and then it bounces and collides with the plane again at p2. I think the ball bounce off the inclined plane at p1 in such a way that the velocity is parallel to the horizontal but this based on the diagram. So if someone could confirm this that would be much help
This is a 4 part problem. The first part I find at what speed the ball collides with the plane at p1. The next one and one I can’t figure out is how much time passes between p1 and p2. The next one is the distance between p1 and p2. I just found the horizontal length between p1 and p2 and divided by the velocity in part 1 because I think just after the collision all of the velocity was directed on the in the x direction. The last part is finding out the velocity of the ball at p2. The way I did this was I found out the vertical distance between p1 and p2 then found the gravitation potential energy between the two points and then set that equal to kinetic energy and found the velocity form need for them to be equal. Then I used Pythagorean Theorem to with legs being the velocity I found to the hypotenuse being the resultant vector.
What you need to do, is to set up a list of what you need to find out, what you know, and finally, what relations held between known and unknown quantities.
THEN, you may attempt to solve the problem:
I'll help you along:
LIST OF WHAT YOU NEED TO FIND OUT:
1. Velocity of ball as it hits P1, let's call this quantity [tex]\vec{v}_{0}[/tex]
2. Velocity of ball as it leaves P1, let's call this quantity [tex]\vec{v}_{1}[/tex]
3. Time&distance from P1 to P2, let's call these quantities [tex]t_{1,2},d_{1,2}[/tex]
Now, what are the quantities that are known to you that might be of help?
1. The ball's mass: m
2. Initial height: h
3. The ball FELL from its initial height.
4. The plane is frictionless
5. The angle is 45 degrees to the horizontal
6. We have an ELASTIC collision.
Now, what relations do we have to work with:
1. Newton's laws of motion!
Thus, we'll need to find laws of force appropriate to the problem:
a) Gravity
b) Normal force from the plane
Are there any others?
Possibly, the problem might be simplified by energy conservation arguments, collision theory, or the like.
For example, can we utilize the kinematic relations we know must hold when the acceleration is constant? (That is, can we find out if the acceleration is constant during some time periods?)
Now, try to set up appropriate equations in which your unkowns appear!
FAQ: Ball collides with an inclined plane
What is a ball colliding with an inclined plane?
A ball colliding with an inclined plane is a physical phenomenon where a round object, such as a ball, rolls down an inclined surface and either bounces off or comes to a stop upon collision.
What factors affect the outcome of a ball colliding with an inclined plane?
The outcome of a ball colliding with an inclined plane can be affected by various factors such as the angle and steepness of the plane, the speed and mass of the ball, and the friction between the ball and the surface of the inclined plane.
How does the angle of the inclined plane affect the motion of the ball?
The angle of the inclined plane affects the motion of the ball by influencing the acceleration and speed of the ball as it rolls down the plane. A steeper angle will result in a faster and more forceful collision, while a shallower angle will result in a slower and gentler collision.
What happens to the ball after it collides with an inclined plane?
After colliding with an inclined plane, the ball can either bounce off and continue to roll down the plane, or it can come to a stop and stay in place. The outcome depends on the angle of the plane, the speed and mass of the ball, and the amount of friction present.
How is the energy transferred during a ball's collision with an inclined plane?
The energy is transferred between the ball and the inclined plane during a collision. When the ball rolls down the plane, it gains kinetic energy due to its motion. Upon collision, some of this energy is transferred to the inclined plane, causing it to move slightly, while the rest is either lost as heat due to friction or used to bounce the ball off the surface.
