Ball dropped down from 5m, what is its speed when it hits the ground
In summary: In your problem, the direction of the initial velocity of the jump is not given. So, you actually don't know the initial x and y components of the velocity that you would plug into the constant-acceleration kinematics equations. By using the energy approach, you do not need to know the direction of the initial...
MrGoATi
sportsman jumps at 5m/s velocity from 5m cliff to water. at what speed does he reach water?
so
given answer is 11.1m/s though in this book there are some wrong answers
(I did try other equations and I got right answer but I want to know why I can't get it using this one)
##g=-10m/s^2##
##v_0=-5m/s##
##h_0=0m##
h=-5m
I'm trying to do this using ##E_k1 + E_p1 = E_k2 + E_p2##
##E_k=\frac {mv^2}{2}##
##E_p=mgh=\frac {2mgh}{2}##
since ##h_0=0## ##E_p1=0##
putting in values
##\frac {mv_0^2}{2}=\frac {mv^2}{2}+\frac {2mgh}{2}##
after multiplying everything by 2 and dividing by m
##v_0^2=v^2+2gh##
##v^2=v_0^2-2gh##
##h=h_1-h_0##
##v^2=(-5)^2-2*(-10)*(-5-0)=25-100=-75##
v=root from -75=impossible. and root from 75 is wrong answer.
if I used one positive number in -2gh part I will get right answer. I think I might need to use |h| in these kind of formulas?
MrGoATi said:
sportsman jumps at 5m/s velocity from 5m cliff to water{/b}. at what speed does he reach water?
so
##g=-10m/s^2##
##v_0=-5m/s##
##h_0=0m##
h=-5m
putting in values
##v_0^2=v^2+2gh##
##v^2=v_0^2-2gh##
##h=h_1-h_0##
if I used one positive number in -2gh part I will get right answer. I think I might need to use |h| in these kind of formulas?[/B]
It depends on how the person jumps from the top of the cliff. Do they jump straight out, or up some, or down some, etc.?
i guess it's as if the person is on a cliff and the cliff suddenly disappears and he is hit at the top of his head which gives him extra 5m/s velocity.
i got an answer on another post though, in ##E_p=mgh##
##g=10m/s^2## instead of
##g=-10m/s^2##
Perhaps but that sounds a bit unlikely..
If someone jumps vertically off a cliff at 5m/s what is their velocity when they pass the cliff edge on the way back down?
Likes berkeman
Stick with the equation...
V2 = U2 + 2gh
Then if up is +ve you correctly used g = -9.8m/s/s but what about the sign of h ?
V2 = U2 + 2gh
sign of h is negative since down is always negative, and the travel was from higher altitude. g is usually negative but in this case it's somehow positive I got this question answered in another post, tho I'm not sure how I got multiple posts of this even though I made 1 XD.
TSny said:
In the potential energy formula mgh, g represents the magnitude of the acceleration of gravity. So, g is a positive quantity.
You defined your starting height as 0m, but that means you start at zero potential. This doesn't work and is the source of your negative. You should define your starting height as 5m and your ending height as 0m, when you have no more potential. Think about the potential (and more specifically the height) this way, if you're going down it's high to low, and if you're going up it's low to high.
In my experience, very few textbooks ever use a negative value for the symbol ##g##. Here's an excerpt from Fundamentals of Physics by Halliday, et. al.
With this convention, the magnitude of weight (in a free body diagram, say) is written simply as ##mg## rather than ##m|g|##. Of course, you are free to make your own sign conventions as long as your choice is clear to those who read your work.
In your problem, the direction of the initial velocity of the jump is not given. So, you actually don't know the initial x and y components of the velocity that you would plug into the constant-acceleration kinematics equations. By using the energy approach, you do not need to know the direction of the initial velocity.
Likes CWatters
If you start at 0m, define up as positive and assume the initial velocity was 5m/s upwards you get...
V2 = (+5)2 + 2(-9.8)(-5)
Which gives the right answer.
You get the same answer if you assume the initial velocity was 5m/s downwards.
You also get the same answer if you assume the initial velocity was 5 m/s outwards, split the initial velocity into x and y components, compute the final y component after the fall and then recombine with the unchanged x component using pythagoras.
Likes CWatters
how could getting right answer by altering values,formulas and known data be helpful? like yeah I can easily get correct answer by changing it to your suggested ideas but when I'm at exam and I do not think of that when trying to do exercise I will still get wrong answer or if I use your idea in some much more complicated issue and then I would possibly get wrong answers again.
i'm trying to do this with maths and physics, not cheats that do not help for my future problems.
These are all correct approaches. None of them are cheats. They correspond to assuming an upward initial velocity, a downward initial velocity or (as in the suggestion I offered), a sideways initial velocity. The resulting impact speed turns out to be the same regardless.
That makes sense since the final speed based on a conservation of energy argument must be the same regardless of the launch angle.
There is often more than one way to analyze a problem. Regardless of what correct analysis you do, the result will be the same.
but g is usually used as a vector and it turns out negative most of the time does it not?
did not think of this that way until now :wideeyed:
in ##F= mg##
##E=mgh##
##s=at^2/2##
it's not a vector so always positive?
and in
##g=v-u/t##
it depends on vector direction?
you just made physics more complicated for me.
ok I guess it's just too complicated for me to understand, the change of up and down makes sense, but pytagoras WT*
Vectors aren't positive or negative. Scalars can be positive or negative. You might occasionally see the notation ##\vec{g}## or g to represent a vector that has magnitude 9.8 m/s2 (on earth) and direction downward. But, the symbol g (no arrow, no bold type) is conventionally used by virtually all the standard textbooks to denote the magnitude of the acceleration due to gravity. With this convention, g is a positive number.
If you choose the positive y direction to be upward, then in projectile motion the acceleration due to gravity would be in the negative y direction. So, with the usual convention for "g", you would write ay = -g. Thus, with g a positive number, ay is negative.
Also, this convention for "g" means that when a mass is at a height h above the ground, then it has gravitational potential energy relative to the ground of PE = mgh. Here, again, g is a positive number.
If you want to go against convention and define g to be negative; i.e., g = -9.8 m/s2, then you can do that as long as it is clear to those who read your work and as long as you write your equations correctly with this convention. For example, for a mass at a height h above the ground, you would now have to write the potential energy with a negative sign: PE = -mgh. PE would still come out positive, as before, but you can see that the signs are inconvenient here.
in ##F= mg##
##E=mgh##
Yes, that's right assuming the usual convention for the meaning of "g" as a positive number.
##s=at^2/2##
I'm not sure in what context you are using this equation. I don't see "g" here.
and in
##g=v-u/t##
I think you might have meant ##g = (v-u)/t##. I'm not sure how you are using this equation.
Sorry, I'm trying to do the opposite :oldfrown:.
As far as I can see I didn't change anything. I used..
MrGoATi said:
g=−10m/s2g=−10m/s2g=-10m/s^2
v0=−5m/sv0=−5m/sv_0=-5m/s
h0=0mh0=0mh_0=0m
h=-5m
Edit: Ah ok so I used -9.8 instead of -10 for g. I missed that bit.
That wasn't Pythagoras ! that was the SUVAT equation of motion V2 = U2 + 2as with a=g=-9.8 and s=h=-5m.
FAQ: Ball dropped down from 5m, what is its speed when it hits the ground
How is the speed of a ball dropped from 5m calculated?
The speed of a ball dropped from 5m is calculated using the equation v = √(2gh), where v is the speed in meters per second (m/s), g is the acceleration due to gravity (9.8 m/s²), and h is the height in meters.
What is the acceleration due to gravity?
The acceleration due to gravity is a constant value of 9.8 meters per second squared (m/s²) on Earth, which means that an object in free fall will accelerate at a rate of 9.8 m/s² towards the ground.
Does the mass of the ball affect its speed when dropped from 5m?
No, the mass of the ball does not affect its speed when dropped from 5m. The speed is determined by the height and the acceleration due to gravity, which are constant values for all objects.
Can the speed of the ball be greater than the calculated value?
No, the speed of the ball cannot be greater than the calculated value. This is because the equation for speed only takes into account the height and the acceleration due to gravity, which are constant values on Earth.
How does air resistance affect the speed of a ball dropped from 5m?
Air resistance can slightly affect the speed of a ball dropped from 5m. However, for most practical purposes, the effect of air resistance can be ignored and the calculated speed using the equation v = √(2gh) can be considered accurate.
