Ball hitting an inclined plane
In summary, we have an inclined plane being hit by an elastic ball moving horizontally. The ball bounces off the plane and lands at the point of first collision. We are asked to determine the ratio between the ball mass and the inclined plane mass. Using conservation of energy, we can deduce that the horizontal distance traveled by the ball is the same as the plane. The vertical and horizontal velocity components of the ball can be determined using basic trigonometry. The impulse delivered by the plane to the ball can be calculated using the equation J = mg cos Θ Δt, and using this, we can find the ratio between the masses in terms of the angle theta.
terryds
392
http://www.sumoware.com/images/temp/xzafcttptkeoehmo.png
An inclined plane is put on a smooth floor. The inclined plane is hit (collided) by an elastic ball moving horizontally before the collision. The ball bounce from the inclined plane and land again right at the point of first collision. If the inclination angle is Θ, determine the ratio between the ball mass and the inclined plane mass
px = px'
E = E'
[/B]
Actually I don't know what to do, so I just draw the condition after collision
http://www.sumoware.com/images/temp/xzknipxthmfhalxb.png
Vp is the velocity of inclined plane
p = p
mb vb = mb vbx' + mp vp'
Then, I don't know what to do
Please help me
Energy is conserved, as the ball is elastic and the ground is smooth.
The ball reaches the plane at the first collision point again. What does it mean for the horizontal distances traveled by the plane and by the ball? What information you have about the vertical and horizontal velocity components of the ball?
Hmm... When the ball reaches the plane at the first collision point, it means that the horizontal distance traveled by the ball is the same as traveled by the plane.
So
p = p
mb vb = (mb + mp)v'x
The vertical component of the ball is v'by = v cos Θ
Horizontal component is v'bx = v sin Θ
(1/2)mvb2 = (1/2)mvb'x2 + (1/2)mvp'x2
(1/2)mvb2 = mvb'x2
vb2 = 2vb'x2
vb2 = 2(vb sin Θ)2
vb = √(2(vb sin Θ)2)
Oops.. It seems like a dead-end to me.. Please help me
So
p = p
Correct.
Why?
ehild said:
Correct.
Why?
Because if theta increases, the y component of the velocity of ball after collision decreases, right ? So, it's cosine function, right ?
And if theta increases, the x component of the velocity of ball after collision increases, right ? So, it's sinus function, right ?
But, I don't know what it will be if the 'launch' angle has nothing to do with the angle theta
There are trig functions besides cos and sine.
Let the impulse the block delivers to the ball be J. Which way does it point? What is its component in the x direction?
http://www.sumoware.com/images/temp/xzaciotcpqkxexdr.png
J = mg cos Θ Δt
Jx = m v'bx - m vb
But, what is v'bx ?
The plane can exert force only in the perpendicular direction, as you drew, but the impulse is not connected to gravity. The parallel (with the plane) component of the initial velocity of the ball does not change during the collision. Only the perpendicular component changes. Conservation of energy provides a relation among the speed of the slope Vp, initial speed of the ball vb, and the perpendicular component after collision, vm.
Both the perpendicular and parallel components of the velocity after collision have horizontal components, depending on the angle theta. You can get an expression for v'bx in terms of theta.
You know that v'bx=Vp, and conservation of momentum yields Vp=mbvb/(mb+mp). There are enough equation to get the mass ratio in terms of theta.
terryds said:
J = mg cos Θ Δt
As ehild says, g doesn't enter into it. Δt is very small.
Deduce J from Jx (simple trig), and deduce Jy from that.
Or use ehild's observation that "The parallel (with the plane) component of the initial velocity of the ball does not change during the collision", which I was trying to avoid assuming. The two methods amount to the same.
Related to Ball hitting an inclined plane
1.
How does the angle of the inclined plane affect the motion of the ball?
The angle of the inclined plane affects the motion of the ball by changing the force exerted on the ball. As the angle increases, the force of gravity pulling the ball down the plane also increases, resulting in a faster acceleration of the ball.
2.
What is the relationship between the height of the inclined plane and the distance the ball will travel?
The height of the inclined plane and the distance the ball will travel are directly proportional. This means that as the height of the inclined plane increases, the distance the ball will travel also increases.
3.
How does the mass of the ball affect its motion on an inclined plane?
The mass of the ball does not directly affect its motion on an inclined plane. However, a heavier ball will experience a greater force of gravity, which may result in a faster acceleration down the plane.
4.
What factors influence the speed of the ball as it rolls down an inclined plane?
The speed of the ball as it rolls down an inclined plane is influenced by several factors, including the angle of the plane, the force of gravity, and the mass and shape of the ball. Friction between the ball and the plane can also affect its speed.
5.
How does the presence of friction affect the motion of the ball on an inclined plane?
Friction between the ball and the inclined plane can slow down the ball's motion, as it acts in the opposite direction of the ball's movement. This means that the steeper the angle of the plane, the more friction the ball will experience, resulting in a slower motion.
