jzwiep
- 21
A 250 g steel ball and a 500 g steel ball each hang from 3.5-m-long strings. At rest, the balls hang side by side, barely touching. The 250 g ball is pulled to the left until the angle between its string and vertical is 22 degrees The 500 g ball is pulled to a 22 degree angle on the right. The balls are released so as to collide at the very bottom of their swings.
What angle does each ball rebound?
Conservation of Energy
U = K' ----> K = U'
Conservation of Momentum (at collision)
p1 + p2 = p1' +p2'
h=L(1-cos(22))
I found the v for both immediately before the collision by:
U=K'
v=sqrt(2g(L-Lcos(22))
Then used that value to find v1 and v2 after the collision with:
-v=2v2' - v1'
and
3v2=v1'2 + 2v2'2
and got two quadratics:
v2
and
v1
I plugged those v values back into the K = U' formula and got:
Theta 1: 14.6636
Theta 2: 8.45
Where did I go wrong?
