Ball speed at the top of the loop
In summary, the conversation discusses using a compressed spring to propel a ball-bearing along a track containing a circular loop. The spring follows Hooke's law and has a force of 0.20 N to compress it to 1.00 mm. The energy stored in the spring when compressed by 30 mm is 0.09 J. When the ball-bearing, with a mass of 0.025 kg, is released, it leaves the spring at a speed of 2.7 m s-1. At the top of the loop, the ball's speed is 1.8 m s-1 and the force exerted on it by the track is 0.55 N. The conversation also discusses the importance of conserving
moenste
711
A compressed spring is used to propel a ball-bearing along a track which contains a circular loop of radius 0.10 m in a vertical plane. The spring obeys Hooke's law and requires a force of 0.20 N to compress it to 1.00 mm.
(a) The spring is compressed by 30 mm. Calculate the energy stored in the spring.
(b) A ball-bearing of mass 0.025 kg is placed against the end of the spring which is then released. Calculate (i) the speed with which the ball-bearing leaves the spring, (ii) the speed of the ball at the top of the loop, (iii) the force exerted on the ball by the track at the top of the loop.
Assume that the effects of friction can be ignored.
Answers: (a) 9 * 10-2 J, (b) (i) 2.7 m s-1, (ii) 1.8 m s-1, (iii) 0.55 N
2. The attempt at a solution
(a) E = 0.5 k x2 → E = 0.5 * [(0.2 * 30) / 0.03] * 0.032 = 0.09 J
(b) (i) KE = 0.5 m v2 → v = √(2 KE) / m = √(2 * 0.09) / 0.025 = 2.7 m s-1
(b) (ii) v = √2 g h = √2 * 10 * 0.2 = 2 m s-1 (in this case I took h as 0.1 + 0.1 -- twice the radius)
or v = √g r = √10 * 0.1 = 1 m s-1
or v = √2 g h = √2 * 10 * 0.1 = 1.4 m s-1
or PE = m g h = 0.025 * 10 * 0.1 = 0.025 J → v = √(2 KE) / m = √(2 * 0.025) / 0.025 = 1.4 m s-1
or PE = m g h = 0.025 * 10 * 0.2 = 0.05 J → v = √(2 KE) / m = √(2 * 0.05) / 0.025 = 2 m s-1
So part (b) (ii) is wrong and I can't see my mistake.
(b) (iii) I took v = 1.8 m s-1 from the answer. ∑ F = N + m g = (m v2) / r → N = [(m v2) / r] - m g = [(0.025 * 1.82) / 0.1] - 0.025 * 10 = 0.56 N
As far as I can see only (b) (ii) is wrong. Any suggestions please on where is the mistake? Thanks in advance.
What is the meaning of all these ors? Why is v = √2 g h ? Write the conservation of mechanical energy equation correctly. KEbottom + PEbottom = KEtop + PEtop. If you can, use symbols and put the numbers in at the end. Then it will be easier to see where you went wrong.
Likes moenste
You forgot to conserve energy. The ball-bearing enters the loop at the bottom with some KE.
Likes moenste
when you are using conservation of energy of a body you must use Initial E (KE +PE) = Final E (KE + PE)
i think you are missing the initial part of energy.
Likes moenste
So we have: KEBottom + PEBottom = KETop + PETop
0.5 m v2 + m g h = 0.5 m v2 + m g h
m is included everywhere, so simplify: 0.5 v2 + g h = 0.5 v2 + g h
PEBottom is equal to 0 since h = 0, so: 0.5 v2 = 0.5 v2 + g h
0.5 * 2.72 = 0.5 v2 + 10 * 0.2 [2.7 m s-1 is the speed with which the body leaves the spring and 0.2 is the height = radius 0.1 *2]
3.645 = 0.5 v2 + 2
1.645 = 0.5 v2
3.29 = v2
v = 1.8 m s-1
This should be it, right?
Likes drvrm
moenste said:
v = 1.8 m s-1
Looks good.
Likes nayagen and moenste
Related to Ball speed at the top of the loop
1. What is the ball speed at the top of the loop?
The ball speed at the top of the loop is determined by the initial speed of the ball and the forces acting on it, such as gravity and air resistance. It will depend on the specific conditions of the loop, such as its radius and the angle of the incline.
2. How does the ball speed at the top of the loop affect its trajectory?
The ball speed at the top of the loop will affect the trajectory of the ball as it continues along the loop. If the ball is moving too slowly, it may not have enough centripetal force to maintain its circular motion and will fall off the loop. If it is moving too quickly, it may experience too much force and be pushed down towards the bottom of the loop.
3. Can the ball speed at the top of the loop be calculated?
Yes, the ball speed at the top of the loop can be calculated using the equations for centripetal force and circular motion. These equations take into account the mass of the ball, the radius of the loop, and the forces acting on it. However, there may be some variables, such as air resistance, that can make the calculation more complex.
4. Is the ball speed at the top of the loop constant?
No, the ball speed at the top of the loop will not be constant. As the ball moves along the loop, it will experience changes in speed due to the forces acting on it. For example, it will slow down as it moves up the incline and then speed up as it moves down the other side.
5. How can the ball speed at the top of the loop be increased?
The ball speed at the top of the loop can be increased by increasing the initial speed of the ball, decreasing the radius of the loop, or increasing the angle of the incline. However, these changes can also affect the forces acting on the ball and must be carefully calculated to ensure the ball stays on the loop.
