Ball thrown vertically, only the time is given
  • Thread starter Wanting to Learn
  • Tags
    Ball Time
In summary, the ball player catches a ball 3.33 s after throwing it vertically upward. To find the initial speed, the equation used is d = v0t + .5at2, where d represents the distance, v0 is the initial speed, t is time, and a is the acceleration due to gravity. By setting the height at the start and end of the throw to be zero, the initial speed can be solved for, which turns out to be 16.3 m/s.
Wanting to Learn
:[/B]
A ball player catches a ball 3.33 s after throwing it vertically upward.
With what speed did he throw it?
What height did it reach?
:[/B]
d = v0t + .5at2
I'm not sure whether this is one of the equations which should be used for this problem.
[I also have from class (just started AP Physics 1) a list of 5 other equations which I could try to post if that would be helpful, I'm not sure what most of them mean/how any of them could be applied (aside from d=tv).]
gravity 9.8 m/s2 (pulling the ball downwards, not sure how to use this info in solving)
3.33s/2=1.665s ball spends going in each direction (up and down)
:[/B]
I'm not really sure how to start/what to do with this problem.
I think there need to be 2 parts, going up and going down.
d = 0 + .5*-9.8*1.665 = -8.1585
m • s = m/s
s2
I'm not sure what this number represents, if it does represent anything. I make acceleration negative because of the gravity pulling down but I'm guessing that is not how it needs to be used. Also I think this ignores the acceleration of the ball being thrown up, which was not given, so I'm very confused about what I should do.
Thank you in advance for any and all help.
How did you arrive at your value for v0?
Do you know the equation for velocity in constant acceleration? v = v0 + a*t
You use this as well as thinking about the symmetry of the problem. If air resistance is neglected, then the trip up will be the same as the trip down.
Also in your equations, are you supposed to just multiply by time, or something else?
Wanting to Learn said:
d = v0t + .5at2
That's pretty close. You do want to use an equation for the vertical motion as a function of time, given some Vo upward and the acceleration of gravity downward (g = 9.8m/s^2 downward). Be sure to include the initial height (which you would set equal to the final height for the full path of the ball from throw-to-catch.
I'd prefer to use Y for the vertical height of the ball, so the equation becomes more like:
[tex] y(t) = y_0 + V_{0y} t - \frac{1}{2}g t^2[/tex]
Can you keep going from there?
EDIT -- oops, scottdave beat me to it... :smile:
ThanksOkay, to make sure I understand what the different variables all mean, is this correct?
y(t) = height (or distance gone) at time t (also known as position)
y0 = position at time 0, is this 0 for the first part (going up?)
V0 = velocity at time 0, this is the unknown? What is the sub y for?
t = time (seconds over which this is happening, in this case 1.665s for each part)
g = 9.8m/s2
So I can plug in
y(t)=y0+V0yt − 1/2 gt2
y(1.1665) = 0 + 1.1665V0y + -.5*9.8*1.1665
=1.665V - 13.5839...
(I worked out the units on paper to be m)​
I'm not sure what to set this equal to, do I use 3.33s for time? I'm not sure that would work because it would be including the 1.1665 seconds I already calculated/accounted for?
Thank you everyone, with your help I figured it out enough to get the correct answer.
The only thing I am still unsure of is why I have to multiply the answer I am getting for the velocity by 2 for it to be correct.
I plugged in:
xf = x0 +Vx0t + .5gt2
0 = 0 + 1.665V + .5*9.8*1.6652
and got V = -8.1585 which I made positive (absolute value) but then had to multiply by 2 for it to be correct , why is that?
(The correct answer is 16.3m/s according to the homework (it's online so you put in answer and it tells you if correct).)
Yes, Vo is one of the unknowns you are asked to solve for.
Later in your class, you will start solving problems in 2 and 3 dimensions. So you will need to keep the x, y, z components accounted for separately. This will lead into solving vector type problems. :smile:l
(I worked out the units on paper to be m)I'm not sure what to set this equal to
I would start by setting y(3.33s) = y(0) = 0. That sets the "datum" or reference height at zero for the start of the throw, and for when you catch it. Then just solve for Voy. Then use the same equation with the now-known Voy to solve for the height at half-flight (half the flight time), which is the top of the ball's travel.
Likes scottdave
I plugged in:
So the time for xfinal=0 is not 1.665 seconds. At 1.665 seconds it has only gone half of the trip, so where is the ball?
If you want to use xfinal = 0, then what should the time be?
Likes berkeman
Oh okay, I think I understand now.
Thank you!
Related to Ball thrown vertically, only the time is given
1. What is the formula for finding the height of a ball thrown vertically?
The formula for finding the height of a ball thrown vertically is h = h0 + v0t - 1/2gt2, where h0 is the initial height, v0 is the initial velocity, t is the time, and g is the acceleration due to gravity.
2. How do you calculate the initial velocity of a ball thrown vertically?
The initial velocity of a ball thrown vertically can be calculated by dividing the change in height by the time it takes to reach that height. This is because the initial velocity and final velocity are equal in a vertically thrown ball.
3. What is the acceleration due to gravity on Earth?
The acceleration due to gravity on Earth is approximately 9.8 m/s2. This means that for every second an object falls, its velocity increases by 9.8 meters per second.
4. How can you use the formula for finding the height of a ball thrown vertically to solve for time?
To solve for time, you can rearrange the formula h = h0 + v0t - 1/2gt2 to t = (√(2h/g)) + (v0/g). Plug in the known values for height, initial height, and initial velocity to find the time it takes for the ball to reach a certain height.
5. What is the maximum height a ball thrown vertically can reach?
The maximum height a ball thrown vertically can reach is determined by the initial velocity and the acceleration due to gravity. It can be calculated using the formula hmax = (v02)/(2g). This means that the higher the initial velocity, the higher the maximum height the ball can reach.
12K
