Ballentine Problem 8.5 (angular momentum)
The discussion focuses on the Ballentine Problem 8.5 related to angular momentum, where the user is grappling with the assumption that the function f must be real-valued to progress in their calculations. They demonstrate that the position and momentum distributions for states labeled by -m and m are equal, relying on properties of complex conjugates and standard equations from quantum mechanics. The user expresses uncertainty about how to proceed without confirming the reality of f, as this affects their ability to manipulate integrals for the final equality. They conclude by questioning whether their approach is valid and if the assumption about f being real is indeed helpful.
EE18
Ballentine asks us "Show that the three-dimensional single particle state functions ##\Psi_{m}(\mathbf{x}):= f(r)Y_l^{m}(\theta,\phi)## and ##\Psi_{-m}(\mathbf{x})## have the same position and momentum distributions."
See below.
I am struggling with the latter, and think that I somehow need to assume ##f## is real-valued to proceed?
My work:
The position distributions are equal since
$$P_{-m}(\mathbf{x}) = |\Psi_{-m}(\mathbf{x})|^2 = |f(r)Y_l^{-m}(\theta,\phi)|^2 = |f(r)(-1)^m(Y_l^{m})^*|^2 = P_m(\mathbf{x})$$
if we recall that the magnitude of a complex conjugate is equal to the original complex number.
The momentum distributions are equal since (using (5.4) and inserting position space completeness twice)
$$P_{-m}(\mathbf{x}) = |\braket{\mathbf{p}}{\Psi_{-m}}|^2 \equiv \braket{\mathbf{p}}{\Psi_{-m}}\braket{\Psi_{-m}}{\mathbf{p}} =\frac{1}{(2\pi\hbar)^3}\int d\mathbf{x} e^{-i\mathbf{p}\cdot\mathbf{x}}f(r)Y_l^{-m}(\theta,\phi)\int d\mathbf{x}' e^{i\mathbf{p}\cdot\mathbf{x}'}f^*(r')(Y_l^{-m})^*(\theta',\phi')$$
$$ \stackrel{(1)}{=} \frac{1}{(2\pi\hbar)^3}\int d\mathbf{x} e^{-i\mathbf{p}\cdot\mathbf{x}}f(r)(-1)^m(Y_l^{m})^*(\theta,\phi)\int d\mathbf{x}' e^{i\mathbf{p}\cdot\mathbf{x}'}f^*(r')(-1)^mY_l^{m}(\theta',\phi')$$
where in (1) we have used (7.37) and its complex conjugate and that ##(-1)^{2m} = 1##.
...But I can't go any further.
The referenced equations in my work are standard equations like the position representation of the momentum eigenstates. In particular, I think that I need to have that ##f## is real so that, after my last step, I can change variables in each integration to minus the given variable and so show the last equality. But I can't do that without being sure ##f## is real!
I observe say f(r) is real
\Phi_{-m}(\mathbf{p}) :=\frac{1}{(2\pi\hbar)^3}\int d\mathbf{x} e^{-i\mathbf{p}\cdot\mathbf{x}}f(r)Y_l^{-m}(\theta,\phi)=\frac{(-1)^m}{(2\pi\hbar)^3}\int d\mathbf{x} e^{-i\mathbf{p}\cdot\mathbf{x}}f(r)Y_l^{m}(\theta,\phi)^*=(-1)^m\Phi^*_{m}(\mathbf{-p})
|\Phi_{-m}(\mathbf{p})|^2=|\Phi_{m}(\mathbf{-p})|^2
Is it helpful ?
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
