Ballistic Pendulum initial velocity of bullet
The bullet has done work on the pendulum, so it's kinetic energy is reduced by that amount. That should be the work done by the bullet, not the work done by gravity. I think you can take it from there.In summary, a ballistic pendulum is used to measure the speed of a bullet fired from a gun by measuring the height it swings up to after embedding itself in a block. Using the equations for work, kinetic energy, and potential energy, the speed of the bullet can be calculated. However, it is important to note that work is not conserved and the work done by the bullet must be taken into account.
MathHelpa
A ballistic pendulum is used to measure the speed of a bullet fired from a gun. The pendulum consists of a 20.0g block hanging from a string. A bullet, with mass 0.50gg, imbeds itself in the block causing the block to swing up to a height of 5.00cm. Find the speed of the bullet as it leave the gun.
W_nc = ΔK + ΔU
K = 1/2 mv^2
U = mgh
W = Fdcos∅
p = mv
I wanted someone to double check my work, and if I used correct units or not.
pendulum
U = mgh
U = (20.0g)(9.8)(0.05cm)
U = 9.8 Joules (this is not gravity it is what mgh came out to)
bullet
K = 1/2 mv^2
9.8(U of pendulum) = 1/2(0.005)v^2
v^2 = 9.8/0.0025
v^2 = 3930
v = 62.6099
v = 62.6 m/s
The bullet EMBEDS itself in the block.
In case you don't understand the significance of voko's comment, you have assumed work is conserved. That is unjustified (and quite wrong here).
Related to Ballistic Pendulum initial velocity of bullet
1. What is a ballistic pendulum?
A ballistic pendulum is a device used to measure the velocity of a projectile, such as a bullet, by observing the motion of a swinging pendulum that has been struck by the projectile.
2. How does a ballistic pendulum work?
When a bullet strikes the pendulum, it transfers some of its momentum to the pendulum, causing it to swing upward. The height of the pendulum's swing can be used to calculate the velocity of the bullet based on the conservation of momentum and energy principles.
3. Why is the initial velocity of a bullet important to know?
The initial velocity of a bullet is important to know for various reasons, such as determining the effectiveness of a firearm, analyzing the trajectory of a bullet, and reconstructing crime scenes.
4. What factors can affect the accuracy of a ballistic pendulum measurement?
The accuracy of a ballistic pendulum measurement can be affected by factors such as air resistance, friction in the pendulum's pivot point, and the weight and shape of the pendulum.
5. Can a ballistic pendulum be used to measure the velocity of any projectile?
Yes, a ballistic pendulum can be used to measure the velocity of any projectile, as long as the projectile is able to strike and swing the pendulum with enough force to produce a measurable swing.
