Band structure and dispersion relations
In summary, the conversation discusses the calculation of partition functions for a Fermi gas and a Bose gas under Harmonic potentials, with the assumption that the particles are non-interacting. The partition functions are represented by a constant "b" and a summation of terms. The conversation also mentions the calculation of the band structure for the Fermion gas and the difference between band structure and dispersion relations for Bosons and Fermions. There are various methods to calculate the band structure, but the best is not specified. Additionally, the conversation touches on the density of states and how it relates to the partition function and energy spectrum. The speaker also expresses confusion about the terminology used in the discussion.
lokofer
106
-Let's suppose we have 2 gases ..one is a "Fermi" gas under an Harmonic potential and the other is a "Bose" gas under another Harmonic potential... in both cases (as an approximation) the particles (bosons and electrons are Non-interacting) then we could write the partition functions.
[tex] \prod _{k=1}^{\infty}(1+be^{\beta \omega (k)})^{-1} [/tex]
Where "b" is a constant equal to 1 (electrons) or -1 (bosons)..my question is HOw could we calculate the "band structure" for the Fermion gas... ¿are the band structure and dispersion relations the "same" concept but one is valid for Bosons and other for Fermions?.. I've read "Ashcroft: Solid State..." where you can find lot's of method to calculate band structure..but what's the best?.., Is there a differential equation or other type of equation satisfied for the [tex] \omega (k) [/tex] in the "Fermionic" case?..thanks.
calculate n(e) i.e the density of states. You keep referring to a dispersion relation, and this euphimism of dispersion relation for w(k). you already know what w(k) is if you know the partition function and hence the energy spectrum. i think you are getting confused with terminogy here as you have presented the same question before and it does not make sense.
The band structure and dispersion relations are related but not exactly the same concept. The band structure refers to the energy levels available for particles in a solid, while the dispersion relation describes how these energy levels change with respect to the momentum of the particles. In the case of a Fermi gas under an Harmonic potential, the band structure will be determined by the energy levels of the harmonic oscillator, while the dispersion relation will describe how these levels change as the momentum of the particles increases.
To calculate the band structure for a Fermi gas, one can use various methods such as the tight-binding approximation, the nearly-free electron model, or the density functional theory. Each method has its own advantages and limitations, and the best approach will depend on the specific system being studied.
In terms of the differential equation satisfied for the \omega (k) in the Fermionic case, it will depend on the method used to calculate the band structure. For example, in the tight-binding approximation, the energy levels are determined by solving the Schrodinger equation, while in the density functional theory, the energy levels are determined by solving the Kohn-Sham equations. These equations will have different forms and solutions, but they all ultimately describe the band structure of the Fermi gas.
Overall, the band structure and dispersion relations are important concepts in understanding the behavior of particles in a solid, and their calculation requires the use of different methods depending on the system being studied.
Related to Band structure and dispersion relations
What is band structure?
Band structure refers to the distribution of energy levels or bands that electrons can occupy in a solid material. It is a fundamental concept in solid state physics and is used to understand the electrical and optical properties of materials.
What is a dispersion relation?
A dispersion relation describes the relationship between the energy and momentum of a particle, such as an electron, in a material. It is a crucial tool for understanding how particles behave in a solid and is often used to calculate properties such as conductivity and optical behavior.
How do band structure and dispersion relations relate?
Band structure and dispersion relations are closely related, as the band structure of a material determines its dispersion relations. In other words, the energy levels and allowed momentum values in a material determine how particles move and behave within that material.
Why is band structure important?
Band structure is important because it helps us understand and predict the properties of materials. For example, the band structure of a material can determine its electrical conductivity, optical properties, and thermal conductivity. This information is crucial for developing new materials for various applications.
How is band structure experimentally determined?
Band structure can be experimentally determined using various techniques such as photoemission spectroscopy, inelastic electron tunneling spectroscopy, and angle-resolved photoemission spectroscopy. These methods involve bombarding the material with particles or photons and measuring the energy and momentum of the emitted particles to create a map of the band structure.
  • Atomic and Condensed Matter
