Band structure and valence electrons
In summary: The core electrons are treated as frozen out because they don't contribute significantly to the wavefunction.In summary, the Born-Oppenheimer approximation is used to derive the band structure for non-local electrons in a periodic potential. The valence electrons are treated as if they live in a periodic potential because of a significant overlap in their wavefunctions.
aaaa202
1,169
The standard approach to explaining band structure is to assume that the electrons in a solid move in a potential from the ions, which is periodic leading to Blochs Theorem and the formation of band structure.
But I am a bit confused at this point. Is the approach only valid for the valence electrons in the solid? I.e. are the electrons assumed frozen out? It seems this is the case in many textbooks. If so, what justifies this approximation? In an earlier post I already touched upon the Born-Oppenheimer approximation, but this is about decoupling the ionic wavefunctions based on the big difference in their masses and not that of the core electrons.
On the other hand, if the approach were valid for all the electrons in the solid it would make sense, since the inert core electrons would then be the ones that occupy the filled up bands and would then offer an explanation for explanation for why it is valid to separate the core- and valence electrons.
I don't quite understand your question. Why would you treat all the electrons in the solid the same way?
The valence electrons are treated the way they do because of a significant overlap in their wavefunctions. This is why you get the tight-binding model and all those hopping parameters. The core electrons are not treated that way because the overlap is insignificant. There's no significant hybridization of the orbitals and they essentially preserved their "atomic" identity. You can't say the same with the valence electrons.
Zz.
Okay so the assumption of electrons living in a periodic potential only holds for the valence electrons? Because if you think about it this is the only ingredient used to derive the band structure.
Two things here:
1. Only "non-local" electrons will have that kind of a periodic potential. After all, if the electron is localized at its "mother atom", it won't see those periodic potential. So already you need a situation where the electronic wavefunction has a significant overlap.
2. The periodic potential is not the only source of a band structure. When you solve the Bloch wavefunction, you made one very important assumption: that the electrons do not interact with each other. They only interact with the periodic boundaries. While this may be OK for simple metals, this is not true in general. I've also mentioned the tight-binding band structure that I've mentioned as another example of obtaining band structure.
Zz.
The electrons moving in a periodic potential of the nuclei is one approximation, basically the Born-Oppenheimer approximation. The electronic wavefunctions formed by the electrons moving in a periodic potential form a complete set of basis functions into which the electronic wavefunctions for other nuclear configurations than periodic can be expanded. That's what you do in the crude adiabatic approximation to describe phonons.
The valence electrons moving in the periodic potential of the core ions is another level of approximation, which is used in semi-empirical methods like tight binding, but not in ab initio methods like DFT.
FAQ: Band structure and valence electrons
1. What is band structure?
Band structure refers to the arrangement of energy levels of electrons in a solid material. This structure is responsible for the material's electrical and thermal properties.
2. How is band structure related to valence electrons?
Valence electrons are the outermost electrons in an atom that participate in bonding. In solids, these electrons form energy bands that determine the material's properties. The number and arrangement of valence electrons greatly influence the band structure of a material.
3. What is the significance of band structure in materials science?
Band structure is crucial in understanding the properties of materials in electronics, optoelectronics, and other fields. It helps scientists predict a material's electrical conductivity, thermal conductivity, and other properties that are crucial in developing new technologies.
4. How does the band structure differ in conductors, insulators, and semiconductors?
In conductors, the valence band and conduction band overlap, allowing electrons to flow freely, resulting in high electrical conductivity. In insulators, there is a large energy gap between the two bands, making it difficult for electrons to move, resulting in low electrical conductivity. In semiconductors, the energy gap is smaller, allowing for some electrons to move, resulting in intermediate electrical conductivity.
5. How do impurities affect the band structure of a material?
Impurities in a material can create energy levels within the energy gap, altering the band structure. This can result in changes in the material's properties, such as increased or decreased conductivity, depending on the type of impurity and its concentration.
