Bandwidth to send signal FSK question, question about terminology
In summary, the bandwidth required to transmit a binary FSK modulated signal with a bit-rate of 112 kbps and a carrier frequency spacing of 10 kHz is 132 kHz.
pokie_panda
37
A binary encoded signal with a bit-rate of Rb = 112 kbps is now encoded using polar NRZ baseband encoding and then modulated using binary FSK with a carrier frequency spacing of 10 kHz. What is the bandwidth required to transmit this modulated signal?
a.132 kHz
b.224 kHz
c.234 kHz
d.112 kHz
w = 2 ×Δfmax + 2rb
Δf = 10kHz
w = 2 ×Δfmax + 2rb
w= 2 x 10 + 2 x 112= 244 kHz.
I think my mistake is to do with Δf max freq. deviation.
Does this mean the distance between f0 - f1 = 10k, making Δf = 5k giving me 234 k
Hi there,
Your attempt at a solution is on the right track, but there are a few things that need to be clarified.
Firstly, for binary FSK, the carrier frequency spacing refers to the difference between the two carrier frequencies used for the two different bits (0 and 1). So in this case, the carrier frequencies would be 10 kHz apart, but the actual spacing would be 20 kHz (since the carrier frequency for bit 1 would be 10 kHz higher than the carrier frequency for bit 0).
Secondly, the formula you have used is correct, but it is usually written as:
w = 2 × Δfmax + Rb
where Δfmax is the maximum frequency deviation and Rb is the bit rate. In this case, Δfmax would be 10 kHz (since that is the spacing between the carrier frequencies) and Rb would be 112 kbps.
So putting it all together, we get:
w = 2 × 10 kHz + 112 kbps = 132 kHz
So the correct answer to the question would be a. 132 kHz.
Hope this helps!
Related to Bandwidth to send signal FSK question, question about terminology
1. What is bandwidth in relation to sending an FSK signal?
Bandwidth refers to the range of frequencies that are necessary to send a particular type of signal. For FSK (frequency-shift keying) signals, the bandwidth required will depend on the difference in frequency between the two tones used in the signal.
2. How is bandwidth related to the data rate of an FSK signal?
Bandwidth and data rate are closely related for FSK signals. The higher the data rate (i.e. the faster the transmission of bits), the wider the required bandwidth will be.
3. What does the term "frequency-shift keying" mean?
Frequency-shift keying (FSK) is a type of modulation technique used to transmit digital data over an analog signal. It involves shifting the frequency of the signal between two distinct values to represent binary data.
4. How is FSK different from other modulation techniques?
FSK is different from other modulation techniques, such as amplitude-shift keying (ASK) and phase-shift keying (PSK), because it uses changes in frequency rather than changes in amplitude or phase to transmit data.
5. Can FSK signals be used for both analog and digital data transmission?
Yes, FSK signals can be used for both analog and digital data transmission. In analog FSK, the frequency changes represent continuous changes in the input signal, while in digital FSK, the frequency changes represent discrete digital bits.
