Banked curves, coefficient of static friction
In summary: Slipping equations without the term: \dfrac{F_x}{R} = -kx## and \dfrac{F_x}{R} = -k(1-x)##.Slipping equations with the term: \dfrac{F_x}{R} = -k(1+x)##.In summary, the term does not have a significant effect on the results.Just comparing @ergospherical 's slipping equations with and without the ##X## term at 20##\frac{km}{hr}## and a presumed 15 degree bank angle.In summary, @ergospherical 's equations show that the term doesn't have a significant effect on the results.
mncyapntsi
38
If a car takes a banked curve at less than the ideal speed, friction is needed to keep it from sliding toward the inside of the curve (a problem on icy mountain roads). (a) Calculate the ideal speed to take a 100.0 m radius curve banked at . (b) What is the minimum coefficient of friction needed for a frightened driver to take the same curve at 20.0 km/h?
tan(theta)-(v^2)/(rg) = us
where us is coefficient of static friction
The solution in my textbook says that for b, us = 0.234. However when I use the formula above I get 0.2364 which I feel like is too far off. Something must have gone wrong...
Any help would be much appreciated!
What is the angle of the bank?
In any case, your equation doesn't look correct. Can you show your work? You can write two equations by applying Newton's second law vertically and horizontally respectively, putting ##F = \mu N## in this limiting case.
[You should end up with an equation of the form ##\mu = \left(\tan{\theta} - \dfrac{v^2}{rg} \right)/X##, where ##X \sim 1## is a term depending on ##v,r,g## and ##\theta##...].
Likes bob012345 and PeroK
What you did is that you decomposed the acceleration due to gravity into components normal and perpendicular to the road, but you didn't do the same with the centripetal acceleration.
Likes Lnewqban
Is it 15 degrees?
In my understanding of how this works, when a student gives a relevant equation it is a given in the problem. I would like to establish if that is true here or if the student derived it first.
At a guess, the student miscopied it.
Perhaps, but it is a reasonable simplification valid at low speeds as shown by @ergospherical in post#3. It could explain the slight numerical discrepancy.
Have you been thinking about a relativistic solution, then?
  • Haha
Likes bob012345
