Banked Turns Part II: What Force Causes a Car to Creep up a Wall
In summary: So the reaction force to the car’s weight is the upwards gravitational pull of the car on the earth.This is correct.
jon4444
68
I wanted to dig deeper on previous question regarding Normal forces and banked turns vs. inclined planes. Intuitively, when a car going around a banked turn is going faster than the "tuned" speed (i.e., the speed at which no friction is required to keep it on the track), it will need friction to prevent it from moving up the wall. I get that this motion ultimately comes from the fact that the car wants to move in a straight line, but how do you conceptualize this motion in terms of forces? And is the Normal force the same at all speeds?
Take the frictionless case for simplicity. Without friction there are two forces, the normal force and the weight. The weight points down. The normal force points in and up. If the speed is just right then the normal force cancels gravity and accelerates you around the track perfectly. If the speed is too fast that means the normal force is too vertical so you accelerate up and do not turn enough, so you go up and off the outside. If the speed is too low then the normal force is too horizontal so you accelerate down and turn too much, so you go down and off the inside.
The force is called a Centripetal force. Take the car and put it in space on the end of a rope. The tension in the rope needs to be the same value force that keeps the car going in a circle of same radius at the same speed on the track. Now, a separate calculation will tell you the angle of track that will produce equilibrium with that force, applied horizontally against the track. (If you allow some lateral friction, the equation becomes a bit more complicated.) I think putting it that way 'explains' the situation usefully but it doesn't give you the answer yet. Another step is needed to tell you the speed needed on a track with a given slope. The Circular Motion equation and the Slope equation (same force in each equation so you can equate them) can be combined and re-arranged to give you the necessary speed.
That is perfectly true but I think you also need to point out that it is the horizontal component of this force that is the required centripetal force. That may not be obvious to someone who is not familiar with 'resolving forces'.
Our friendly Hyperphysics Website gives the explanation of the relationships between all the factors. Put in your own figures (including frictionless option) and use the ready made calculator.
I think the conceptual aspect of the situation I want to be clear on is that the Normal force increases as the speed increases, correct? And explaining why this is, is what I would like to be clear on. What I might say is that the Normal force in the situation where the speed is "too fast" is made up of a reaction force to gravity pulling down and a separate reaction force to the car banging against the wall (since the car wants to go straight, but the wall wants to turn it.)
Can you clarify that explanation any or provide better language?
Thx.
The normal force is never a reaction force to gravity. Action-reaction pairs are always of the same type. So the reaction force to the car’s weight is the upwards gravitational pull of the car on the earth.
This is closer. The reaction is to the contact force of the car against the road. However, the whole action reaction framework here is not terribly helpful. Yes, if you know the force of the road on the tires then that is equal and opposite to the force of the tires on the road. But that doesn’t tell you much since the force of the road on the tires is no more nor less confusing than the force of the tires on the road. I would probably avoid the third law here.
The key is to recognize that the normal force is whatever value it needs to be to prevent the car from sinking into the road. That value depends on the speed. At high speed the acceleration required to not sink is higher so the force is correspondingly higher.
Because the acceleration required to avoid sinking into the road increases with speed.
FAQ: Banked Turns Part II: What Force Causes a Car to Creep up a Wall
1. What is the force that causes a car to creep up a wall?
The force that causes a car to creep up a wall is the centripetal force. This is the force that acts towards the center of the circular motion and keeps the car moving in a curved path.
2. How does the centripetal force allow a car to defy gravity and climb up a wall?
The centripetal force is constantly changing the direction of the car's motion, causing it to move in a circular path. This change in direction allows the car to climb up the wall, as it is no longer moving straight downwards due to gravity.
3. What factors affect the strength of the centripetal force?
The strength of the centripetal force depends on the speed of the car, the mass of the car, and the radius of the circular path it is traveling on. The faster the car is moving, the greater the centripetal force needed. A heavier car also requires a stronger centripetal force, and a smaller radius of the circular path will increase the force needed.
4. How does the angle of the banked turn affect the centripetal force?
The angle of the banked turn affects the centripetal force by changing the direction of the force. In a properly banked turn, the force will act at an angle towards the center of the turn, allowing the car to maintain its speed without sliding or slipping off the track. If the angle is too steep or too shallow, the force may not be enough to keep the car on the track.
5. Can the centripetal force cause a car to climb up a wall without any other external forces?
No, the centripetal force alone cannot cause a car to climb up a wall. The force of gravity still acts on the car, and it is the combination of the centripetal force and the normal force from the wall that allows the car to climb up. Without the normal force, the car would simply continue in a circular path without climbing up the wall.
