Bar magnet at constant velocity, what is the direction of the induced current?
In summary, the graph of the induced current in the loop as a function of time will resemble a sine wave, with counterclockwise currents being positive and clockwise currents being negative. This is due to the change in magnetic field passing through the loop as the bar magnet is spun at a constant angular speed, according to Faraday's law and Lenz's law. The amplitude of the graph will depend on the strength of the magnetic field and the size of the loop.
imatreyu
82
A bar magnet is spun at constant angular speed w around an axis as shown in Figure P31.38. A stationary flat rectangular conducting loop surrounds the magnet, and at t = 0, the magnet is oriented as shown. Make a qualitative graph of the induced current in the loop as a function of time, plotting counterclockwise currents as positive and clockwise currents as negative.
I don't even know how to start this.
Of course, Lenz's law is relevant. . .Do I have to use the right hand rule to determine the direction of the currents?
I'm pretty sure that the graph ultimately resembles a sin graph, but I don't understand why.
Thank you, in advance )))
Dear forum post author,
Thank you for your question. Yes, Lenz's law is indeed relevant in this scenario. To determine the direction of the induced currents, you can use the right hand rule. As the magnet is spun at a constant angular speed, the magnetic field passing through the loop will also change at a constant rate. According to Faraday's law, this change in magnetic field will induce an EMF (electromotive force) in the loop, which in turn will cause the induced currents to flow in the loop.
Since the magnet is initially oriented as shown in the figure, the magnetic field passing through the loop will increase as the magnet spins counterclockwise. This will induce a counterclockwise current in the loop, as per Lenz's law. As the magnet continues to spin, the magnetic field passing through the loop will decrease, causing the induced current to decrease and eventually change direction. This will result in a negative (clockwise) current in the loop.
As the magnet completes one full rotation, the induced current will complete one full cycle, resulting in a graph that resembles a sine wave. This is because the magnetic field passing through the loop is changing at a constant rate, resulting in a sinusoidal variation of the induced current. The amplitude of the graph will depend on the strength of the magnetic field and the size of the loop.
I hope this helps you understand the concept better. If you have any further questions, please do not hesitate to ask. Good luck with your studies!
Scientist
Related to Bar magnet at constant velocity, what is the direction of the induced current?
1. What is a bar magnet?
A bar magnet is a type of magnet with a rectangular shape that has a north and south pole. It is made of a magnetic material, such as iron, and generates a magnetic field.
2. What is meant by "constant velocity"?
Constant velocity refers to the motion of an object at a steady speed in a straight line without any change in direction. It means that the bar magnet is moving at a constant speed without accelerating or decelerating.
3. How does a bar magnet at constant velocity create an induced current?
As the bar magnet moves through a conductor, such as a wire, it creates a changing magnetic field. This changing magnetic field induces an electric current in the wire, known as an induced current. The direction of the induced current is determined by the direction of the changing magnetic field.
4. Will the direction of the induced current change if the bar magnet changes direction?
Yes, the direction of the induced current is always perpendicular to the direction of the changing magnetic field. So, if the bar magnet changes direction, the induced current will also change direction.
5. What factors can affect the direction of the induced current in a bar magnet at constant velocity?
The direction of the induced current is determined by the direction of the changing magnetic field, which can be affected by the strength of the bar magnet, the speed at which it is moving, and the angle at which it is approaching the conductor. Additionally, the material and length of the conductor can also influence the direction of the induced current.
