Barbell in gravitational field (Lagrange)
In summary, the conversation discusses a new Lagrange problem involving a barbell composed of two masses in Earth's gravitational field. The Lagrange function is written using spherical coordinates for the relative vector and cartesian coordinates for the center of mass. The equations of motion are derived, including one special solution, and the conserved quantities in the system are discussed. However, there is some uncertainty about the correctness of the solution and the value of the angle variable in the equations of motion.
  • #36
I gave it a go and that's what I came up with so far. Since I am in the middle of that lesson, I attempted solving it with informations found here and there on the internet and in our script, so I hope it makes sense.
##\frac{\partial V}{\partial t} = 0 \implies E = T+V = const. \implies \mbox{ Energy is conserved.}##
##\mbox{Total (linear) momentum: } P = \sum p_i = (m_1 + m_2)(\dot{x}^2 + \dot{y}^2 + \dot{z}^2)##
##\frac{d}{dt} P = (m_1 + m_2)(\ddot{x}^2 + \ddot{y}^2 + \ddot{z}^2) = (m_1 + m_2)(0 + 0 + g^2) \neq 0##
##\implies \mbox{Linear momentum is not conserved.}##
##\mbox{Angular momentum: } \frac{d}{dt} \frac{\partial L}{\partial \dot{\varphi}} = 0##
##\implies \frac{\partial L}{\partial \dot{\varphi}} = const. \implies \mbox{ Angular momentum is conserved.}##
Now I am not sure what represents ##\theta##. Could it be that ##\frac{\partial L}{\partial \dot{\varphi}} = mr^2 \dot{\varphi} \sin^2 \theta## refers to the angular momentum with respect to the z-axis while ##\frac{\partial L}{\partial \dot{\theta}} = mr^2 \dot{\theta}## would refer to the angular momentum with respect to the x,y-plane? I would add that whatever it is I think it is not conserved, because ##\frac{\partial L}{\partial \dot{\theta}} \neq 0##.
I have some doubts about the linear momentum. I thought that ##x##, ##y##, ##z## were the only translations possible for ##m_1## and ##m_2##. Could that be right?Julien.
  • #37
JulienB said:
I got for ##\varphi##:
##\ddot{\varphi} = mr^2 \sin^2 \theta \dot{\varphi} = mr^2 k = 0##
The first equality is not true (I don't think you meant to type that). However, ##mr^2 \sin^2 \theta \dot{\varphi} = mr^2 k## is correct.
##\implies \dot{\varphi} = const.##
This is true, but I'm not sure how you deduce that. Note that ##mr^2 \sin^2 \theta \dot{\varphi} = mr^2 k## implies that ##\sin^2 \theta \; \dot{\varphi} ## is constant. But this by itself does not imply that ##\dot{\varphi} ## is constant.
##\dot{\varphi}_0 = 0 \implies \dot{\varphi} = 0 \implies \varphi = \varphi_0 = \frac{\pi}{6}##
OK. Here's how I would get those results. The initial condition ##\dot{\varphi}_0 = 0## implies that the constant ##k = 0## (using ##mr^2 \sin^2 \theta \dot{\varphi} = mr^2 k## ). Therefore, ##mr^2 \sin^2 \theta \dot{\varphi} = 0## at all times.
You also have ##\ddot{\theta} = \frac{k^2}{\sin^2 \theta \tan \theta}##. Since ##k = 0## in this example, ##\ddot{\theta} = 0## at all times. Since you also have the initial condition ##\dot{\theta} = 0##, ##\theta## remains constant at the initial value ##\pi/4##.
Then, going back to ##mr^2 \sin^2 \theta \dot{\varphi} = 0## at all times, you can conclude that ##\dot{\varphi} = 0## at all times. So, ##\dot{\varphi}## remains constant at ##\pi/6##.
Thanks a lot for your valuable help. If you ever come to Berlin let me know and you'll get a piece of cake and a coffee for free in our café :)
Thanks! Maybe I will.
  • #38
OK, energy is conserved.
Linear momentum is a vector. ##\vec{P} = (m_1+m_2) \left( \dot{x} \hat{i} + \dot{y} \hat{j} +\dot{z} \hat{k} \right)##
Are there any components of the total linear momentum that are conserved?
As you note below, this is showing that the angular momentum about the z-axis is conserved. More specifically, it is the z-component of the angular momentum of the two masses as measured relative to the center of mass of the barbell. That is, it's the z-component of angular momentum due to the rotation of the barbell about its center of mass. It does not include any angular momentum due to translation of the center of mass of the barbell.
Yes this a little tricky. The quantity ##\frac{\partial L}{\partial \dot{\theta}} = mr^2 \dot{\theta}## can be interpreted as the angular momentum relative to the center of mass about an axis parallel to the xy plane. This axis is perpendicular to the vertical plane that contains the z-axis and instantaneous position of the particle. But this axis is not fixed. This axis changes direction as ##\varphi## changes. So, ##mr^2 \dot{\theta}## does not represent a component of angular momentum about a fixed axis in the inertial (earth-based) frame. As you note, this quantity is not conserved.
  • #39
I've pretty much done the same, I think you misinterpreted my first equality, or maybe I should have it described it more precisely. Anyway that was very instructive for me.
I think all linear momentum taking place in the x and y directions are conserved, but not in the z direction. That makes sense, since an external force (gravity) is applying in that direction.
If I understand correctly, for this angular momentum to not be conserved, there must be an external force applying and the only one I see is gravity. It is indeed a little difficult to grasp, but it would make sense since you describe the axis parallel to the xy plane.
Thanks a lot, it's always nice to get some physical intuition! See you in another post. ^^
Anytime!Julien.
