Barometric law for hard sphere sedimentation
In summary, the Barometric Law in terms of density can be expressed as: \frac{\phi(z)}{\phi_{0}}=exp(-g.M.z/R.T), where R is the Universal gas constant, z is the height of sedimentation, T is the standard temperature, g is the gravitational acceleration, and M is the molar mass. When calculating the height of the universe, the molar mass used is that of the atmosphere. However, when calculating the height of a colloid sedimentation, the molar mass refers to the mass of the colloid, the average mass of the colloid and solvent, or the relative mass of the colloid in the given solvent. This equation may not be applicable to all collo
KayDee01
So I have the equation for Barometric law in terms of density as: [itex]\frac{\phi(z)}{\phi_{0}}[/itex]=exp([itex]-g.M.z/R.T[/itex]) where R=Universal gas constant, z=height of sedimentation, T=Standard temperature, g=Gravitational acceleration, M=Molar mass.
When this equation is used to calculate the height of the universe, the molar mass is the molar mass of the atmosphere. But if you're using it to calculate the height of a colloid sedimentation when you have a colloid solution, is the molar mass referring to the mass of the colloid, the average mass of the colloid and solvent, or the relative mass of the colloid (i.e. buoyant mass of the colloid in the given solvent)??
This isn't a homework question, I'm just wondering what factors are being taken into account when calculating the height of a colloid sediment.
The height of the Universe? LOL.
This is not a law. A Law is a physical principle which has very broad utility and has been extensively tested. The Barometric equation qualifies under neither requirement. It applies ONLY to ideal gasses, AND, can only apply near sea-level (as given here). I don't know ANY colloids that do not settle given sufficient time in an unstirred isothermal container (which turns out to be extremely difficult to actually construct). Yet, your "Law" contains no time dependence. How do you have sedimentation without time? You are correct to suspect that talking about colloids as if their density is irrelevant is a fools errand. Packing of a sediment is usually characterized as hard or soft, but obviously must depend on particle to particle interactions, as well as particle volume and shape.
I would never use this to predict sediment volume (height). But then, perhaps it's "good enough" for geology/hydrology?
I think you're right, that the difference in density between the solvent and the solute (as it exists in solution) is the correct parameter to use to predict Φ/Φ₀.
Related to Barometric law for hard sphere sedimentation
1. What is the Barometric Law for Hard Sphere Sedimentation?
The Barometric Law for Hard Sphere Sedimentation is a scientific principle that describes the relationship between the sedimentation rate of hard sphere particles and their size, density, and the viscosity of the fluid they are suspended in. It states that the sedimentation rate is directly proportional to the difference in density between the particle and the fluid, and inversely proportional to the particle size and fluid viscosity.
2. What are the key factors that affect the sedimentation rate according to the Barometric Law?
The key factors that affect the sedimentation rate according to the Barometric Law are the size and density of the particles, and the viscosity of the fluid. These factors determine how quickly the particles will settle through the fluid due to gravity.
3. How is the Barometric Law applied in practical situations?
The Barometric Law is often applied in the study of sedimentation, such as in the analysis of sedimentation data in geology and environmental science. It is also used in industrial processes, such as the separation of particles in wastewater treatment or the production of pharmaceuticals.
4. Can the Barometric Law be applied to all types of particles?
No, the Barometric Law is specifically applicable to hard sphere particles, which are uniform in shape and do not deform or adhere to each other. For particles that do not fit these criteria, other sedimentation laws may need to be used.
5. What are the limitations of the Barometric Law for Hard Sphere Sedimentation?
The Barometric Law assumes that the particles are settling in a dilute suspension and that there are no interactions between the particles. In reality, these conditions may not always be met, leading to deviations from the predicted sedimentation rate. Additionally, the law does not take into account other factors that may affect sedimentation, such as fluid flow or temperature changes.
  • Classical Physics
