Barrier Tunneling and Kinetic Energy
In summary, the question asks to find the kinetic energy of a proton on the other side of a potential barrier if it tunnels through or reflects from the barrier. Using the transmission coefficient formula, T= e^-2bL, and the barrier equation, b= sqrt(((8pie^2)(m)(U(sub b)-E))/(h^2)), the transmission coefficient is found to be T= e^-11.617 or (9.011*10^-6). However, the relation between kinetic energy and b is not clear. Regardless, the energy of the proton remains unchanged in both cases due to conservation of energy. This concept applies to other particles as well.
nickm4
1. Homework Statement
b). Find the kinetic energy K (sub t), the proton will have on the other side of the barrier if it tunnels through the barrier.
c) Find the kinetic energy K (sub r), it will have if it reflects from the barrier.
Variables:
Transmission Coefficient (T)
T= e^-2bL
T was found to be T= e^-11.617 or (9.011*10^-6)
e= 2.718...
L= length of the barrier which is given as 10fm or (10.0*10^-15m)
m= mass of proton(1.673*10^-27kg)
Ub= height of the potential barrier(given= 10MeV)
E= energy of the proton (given= 3MeV)
h= plank's constant (6.62*10^-34)
2.
T= e^-2bL
I solved the first part of the question to find the transmission coefficient, T. But I'm not sure how Kinetic energy is related. Other than through b.
This question is taken from " Fundementals of Physics" Halliday/Resnick 7th ED. Question: 38-63
Thanks Tons.
In both cases (reflection and tunneling) the energy remains unchanged. By conservation of energy the energy cannot change because it is not going anywhere. This holds for electrons and other particles as well.
I would like to provide a response to the content regarding barrier tunneling and kinetic energy. First, it is important to understand the concept of barrier tunneling. When a particle, in this case a proton, encounters a potential barrier, it has a certain probability of passing through the barrier rather than being reflected back. This phenomenon is known as barrier tunneling.
In this specific question, we are given the transmission coefficient (T) which represents the probability of the proton tunneling through the barrier. Using this information, we can calculate the kinetic energy (K) of the proton on the other side of the barrier using the equation K = (1-T)E, where E is the initial energy of the proton. This means that if the proton successfully tunnels through the barrier, it will have a kinetic energy equal to the initial energy minus the energy reflected back.
On the other hand, if the proton is reflected back from the barrier, it will have a kinetic energy equal to the initial energy (E). This is because the transmission coefficient is equal to zero and therefore there is no energy loss due to tunneling.
To further understand how kinetic energy is related to barrier tunneling, it is important to look at the equations provided in the problem. The parameter b, which is used to calculate the transmission coefficient, is also used in the equation for kinetic energy as b = sqrt(((8pie^2)(m)(U(sub b)-E))/(h^2)). This shows that as b increases, the transmission coefficient decreases, meaning that the probability of tunneling decreases. This results in a higher kinetic energy for the proton if it is reflected back from the barrier.
In conclusion, barrier tunneling and kinetic energy are closely related in this scenario. The transmission coefficient determines the probability of tunneling and subsequently, the kinetic energy of the proton on the other side of the barrier. I hope this explanation helps to clarify any confusion and provides a better understanding of these concepts.
FAQ: Barrier Tunneling and Kinetic Energy
What is barrier tunneling?
Barrier tunneling is a quantum mechanical phenomenon where a particle with insufficient kinetic energy to overcome a potential barrier can still pass through it. This is possible because of the wave-like nature of particles at the quantum level.
What is the significance of barrier tunneling?
Barrier tunneling is important in various scientific fields, such as solid-state physics, nuclear physics, and quantum mechanics. It allows particles to pass through energy barriers that would be impossible to overcome based on classical mechanics, leading to new insights and applications in these fields.
How does kinetic energy affect barrier tunneling?
The amount of kinetic energy a particle has is directly related to its probability of undergoing barrier tunneling. As the kinetic energy increases, the probability of tunneling decreases, and the particle is more likely to reflect off the barrier. Therefore, higher kinetic energy particles are less likely to undergo barrier tunneling.
What factors influence the rate of barrier tunneling?
The rate of barrier tunneling is influenced by several factors, such as the height and width of the barrier, the particle's mass and kinetic energy, and the shape of the potential barrier. Additionally, the presence of other particles and external forces can also affect the rate of tunneling.
What are some real-world applications of barrier tunneling?
Barrier tunneling has practical applications in various technologies, including scanning tunneling microscopy, which uses the tunneling of electrons to create images of surfaces at the atomic level. It also plays a role in the operation of tunnel diodes and flash memory devices. Additionally, barrier tunneling is crucial in understanding the behavior of particles in nuclear reactions and the properties of semiconductors and superconductors.
