Baryon number conservation in early universe when T<m
In summary: The number density of nucleons is determined by the laws of physics and is not affected by the chemical potential.
karlzr
131
When temperature of the universe falls below nucleon mass ##T<<1## GeV, the number densities of nucleons (proton and neutron) which are in kinetic equilibrium can be obtained as
##n_i=g_i (\frac{m_i T}{2\pi})^{3/2} e^{\frac{\mu_i-m_i}{T}}##. Since baryon number should be conserved, then I expect ##n_p+n_n \propto a^{-3} \propto T^{3}##, which is not obvious from the above formula. I have taken for granted that there are no anti-particles for nucleons and all baryon number is in proton and neutron. So what 's going wrong? Does chemical potential have anything to do with it?
What do we know about antiproton/antineutron? Do they annihilate with proton/neutron around ##T\approx m_i## or what? I am trying to relate this process with that in Tevatron.
Space news on Phys.org
For a species that was non-relativistic at decoupling, ##T \propto a^{-2}##. Consequently, if the chemical potential is small compared the mass, and the mass is small compared to ##T##, the exponential is unity, and
$$n_i \propto T^{3/2} \propto \left(a^{-2}\right)^{3/2} \propto a^{-3},$$
as expected.
as expected.
But when temperature is lower than mass the exponential dies out rather than being unity.
Do you mean nucleons have different temperature as photons during nucleosynthesis?
Thanks.
I don't think it's possible to obtain the number density of baryons purely from thermodynamic arguments. You also need to know the level of asymmetry between matter and anti-matter generated by CP violation in the very early universe.
Thanks.
Sorry, I didn't read your post very carefully, and I was thinking about something different.
My question is not about baryogenesis. I am considering the era from some temperature when QCD phase transition has already finished, saying 100 MeV to nucleosynthesis at ##T\approx1## MeV. The correct density of baryons has already been generated by some unknown mechanism before this period.
I know during this period the total baryon number must be conserved and I am asking why based on the discussion from thermodynamics. Now I think the answer lies in chemical potential which depends on temperature to ensure baryon number conservation.
I don't think it has anything to do with that. The number of remaining baryons is simply not thermodynamically-determined at all.
One simple way to look at it is this:
In a co-moving volume, you have ##N## anti-baryons and ##N + \epsilon## baryons early-on.
##N## is determined by thermodynamics (the formulas you're using above).
##\epsilon## is exclusively determined by the properties of baryogenesis. After baryogenesis has finished, we can simply take it as a fixed parameter.
Conservation of baryon number is a function of how the strong and weak nuclear forces behave. There's no reason to worry about a chemical potential, as it's not a thermodynamic process. Just take some leftover density as a fixed parameter and be done with it.
That is to say, you can simply write:
[tex]n_i = g_i\left({m_i T \over 2\pi}\right)^{3 \over 2} e^{\mu_i - m_i \over T} + {\epsilon_i \over a^3}[/tex]
This equation will not be accurate while baryogenesis is occurring, and nucleosynthesis will mix things up a little bit, but it provides a rough idea of how this works.
The chemical potential really has nothing to do with this as that refers to the potential energy associated with reactions.
Do you mean thermodynamics or statistical distribution function doesn't work very well in this case? As to chemical potential, it is not constant. So how does it change with temperature?
I didn't say the net baryon number is determined from thermodynamics. I am trying to understand how the universe keeps this number unchanged after baryogenesis while nucleons are still in equilibrium with cosmic plasma. And my conclusion was: assuming the validity of distribution function, the only explanation lies in chemical potential.
The distribution function.
That distribution function was constructed with the assumption that as T goes to zero, so does the number density, that is, that there are an equal number of matter and anti-matter particles. If you *really* want to do it right, you would have to go back and look at how the equation was derived in the first place, and add in the fact that there is some imbalance in matter/anti-matter. I'm sure this has been done, of course, but I'm really not sure how I'd go searching for it.
Related to Baryon number conservation in early universe when T<m
What is baryon number conservation in the early universe when T
Baryon number conservation refers to the principle that the total number of baryons (protons and neutrons) in the universe remains constant over time. When the temperature of the universe drops below a certain threshold (T
Why is baryon number conservation important in the early universe?
Baryon number conservation is important because it helps to explain the abundance of matter in the universe. If baryon number conservation did not hold, we would expect to see equal amounts of matter and antimatter in the universe, which is not the case. The fact that there is significantly more matter than antimatter suggests that baryon number conservation is a fundamental principle in the early universe.
How does baryon number conservation affect the formation of galaxies and other large structures?
Baryon number conservation plays a crucial role in the formation of galaxies and other large structures in the universe. As matter and antimatter particles collide and annihilate each other, the remaining baryons clump together and eventually form galaxies. Without baryon number conservation, this process would not be possible and the universe would look very different.
Can baryon number conservation be violated?
While baryon number conservation is a fundamental principle in the early universe, there are some theories that suggest it may be violated under certain conditions. For example, the theory of baryogenesis proposes that a small violation of baryon number conservation in the early universe could explain the observed matter-antimatter asymmetry.
What are the implications of baryon number conservation for the future of the universe?
As the universe continues to expand, the density of baryons will decrease. This means that baryon number conservation will become less important over time. However, it is still a crucial principle in explaining the current state of the universe and the formation of structures such as galaxies and stars.
