Baryon oscillation peak a cosmological standard ruler
In summary, the article discusses the possibility of the baryon acoustic oscillation (BAO) peak location being a cosmological standard ruler. However, recent evidence suggests that the BAO peak location is strongly affected by structure formation and is not a constant ruler. This poses a challenge for using it as a standard ruler in cosmological measurements and further research is needed to understand and calibrate this dependence.
wolram
Dearly Missed
4,446
558
This came up in the arxivs and had me thinking can this be true? arXiv:1506.05478 [pdf, ps, other]
Is the baryon acoustic oscillation peak a cosmological standard ruler?
Boudewijn F. Roukema, Thomas Buchert, Hirokazu Fujii, Jan J. Ostrowski
Comments: 4 pages, 2 figures
Subjects: Cosmology and Nongalactic Astrophysics (astro-ph.CO); General Relativity and Quantum Cosmology (gr-qc)
In the standard model of cosmology, the Universe is static in comoving coordinates; expansion occurs homogeneously and is represented by a global scale factor. The baryon acoustic oscillation (BAO) peak location is a statistical tracer that represents, in the standard model, a fixed comoving-length standard ruler. Recent gravitational collapse should modify the metric, rendering the effective scale factor, and thus the BAO standard ruler, spatially inhomogeneous. Using the Sloan Digital Sky Survey, we show to high significance (P < 0.001) that the spatial compression of the BAO peak location increases as the spatial paths' overlap with superclusters increases. Detailed observational and theoretical calibration of this BAO peak location environment dependence will be needed when interpreting the next decade's cosmological surveys.
Space news on Phys.org
Hi Wooly, it has been said (I forget by whom) that when you have a title ending in a question mark the implied answer, or default, is NOT.
That seems to be the answer here, at least for the time being, if you go by the article's conclusions paragraph at the end:
==quote http://arxiv.org/abs/1506.05478 ==
5 CONCLUSION
No matter which approach is chosen, analytical, numerical and observational work will be required if the BAO peak location is to correctly function as a standard ruler for cosmological geometrical measurements, since the evidence is strong (P < 0.001) that it is strongly affected by structure formation. Moreover, the formation of superclusters—in reality, filamentary and spiderlike distributions of galaxies (Einasto et al. 2014) rather than the spherically symmetric objects assumed here for calculational speed—can now be tied directly to a sharp statistical feature of the primordial pattern of density perturbations.
==endquote==In other words the BAO peak location is not a constant it is strongly affected by the static large-scale environment.
An interesting thing to notice, though, is that when you describe the universe in comoving coordinates there is no expansion. On a large enough scale the coordinate locations of major matter concentrations stay the same. You have a static universe, if you use comoving coordinates, at least in the large, ignoring little local curdlings and swirlings around. The authors mention that.
What seems to interest people about the BAO peak location is they see it as a possible natural scale to use in describing the frozen ripples and other structure in this static picture. It strikes me as a worthwhile endeavor.
It would not carry over as a fixed-length ruler to describe the expanding universe. Because it wouldn't stay the same size but would vary widely over time. But they are pointing out something more serious. It even varies from place to place in the comoving coordinates universe (even after the expansion has been factored out of the picture).
So their basic conclusion seems to be that the idea "needs work."
I've only skimmed the paper but this idea that the BAO peak is affected by non-linear evolution isn't particularly new. A lot of simulation work goes into determining these sorts of biases and finding the best estimators and reconstruction methods which are insensitive to it. It's one of the challenges with DESI and Euclid.
Related to Baryon oscillation peak a cosmological standard ruler
What is the Baryon Oscillation Peak?
The Baryon Oscillation Peak is a feature in the large-scale structure of the universe that represents a standard ruler for measuring distances in cosmology. It is caused by acoustic waves in the early universe that were trapped in the hot plasma and later imprinted on the distribution of matter.
Why is the Baryon Oscillation Peak important?
The Baryon Oscillation Peak is important because it provides a standard ruler for measuring distances in the universe. By studying the location and size of this peak, scientists can accurately measure the expansion rate of the universe and the amount of dark energy present.
How is the Baryon Oscillation Peak measured?
The Baryon Oscillation Peak is typically measured using data from large surveys of galaxies, such as the Sloan Digital Sky Survey. These surveys map the distribution of galaxies in the universe, and the Baryon Oscillation Peak can be seen as a characteristic bump in the distribution of galaxies.
What does the Baryon Oscillation Peak tell us about the universe?
The Baryon Oscillation Peak provides important information about the structure and evolution of the universe. It can be used to measure the expansion rate of the universe, the amount of dark energy present, and the overall geometry of the universe.
How does the Baryon Oscillation Peak relate to dark energy?
The Baryon Oscillation Peak is closely related to dark energy, as it can be used to measure the amount of dark energy present in the universe. By studying the location and size of the peak, scientists can determine the rate at which dark energy is pushing the universe apart.
  • Cosmology
  • Cosmology
  • Beyond the Standard Models
  • Cosmology
