deekin
- 72
A baseball (radius = 0.0366m, mass = 0.145kg) is dropped from rest at the top of the Empire State Building (height = 1250ft = 381m). Calculate (a) the initial potential energy of the baseball, (b) its final kinetic energy, and (c) the total energy dissipated by the falling baseball by computing the line integral of the force of air resistance along the baseball's total distance of fall. Compare this last result to the difference between the baseball's initial potential energy and its final kinetic energy.
F = ma = -mg -cv
P.E.=mgh
[itex]c=1.1346\cdot 10^{-5}[/itex]
For part a, it was easy to find the potential energy.
mgh = (0.145kg)(9.8m/s2)(381m) = 541 J
Part b is where I am stuck. I took down to be negative. For the force, we have
[itex]F = ma = -mg - cv[/itex]
since I was told by the professor to use the linear term rather than quadratic. Then we have
[itex]ma=mv\frac{dv}{dx}=-mg-cv\Rightarrow \frac{mvdv}{-mg-cv}=dx[/itex]
[itex]\Rightarrow \int \frac{mvdv}{-mg-cv}=\int dx[/itex]
Where the limits of integration on the left are from [itex]v_0=0[/itex] to [itex]-v_f[/itex] and the limits of integration on the right are from [itex]x_0=381m[/itex] to [itex]x_f=0[/itex]. We now have
[itex]\frac{-mv}{c}+\frac{m^2g\ln(mg+cv)}{c^2}[/itex] evaluated using the bounds mentioned above, this is the left hand side. The right hand side is [itex]x_f-x_0=-381m[/itex].
Now we have
[itex]\frac{mv_f}{c}+\frac{m^2g\ln(mg-cv_f)}{c^2}-\frac{m^2g\ln(mg)}{c^2}=-381[/itex]
I tried solving this numerically just using Maple, but the value I got for the final velocity does not make sense when I compare my answer for the final kinetic energy to the back of the book. The back of the book has the final kinetic energy as 87 J. Using the equation for kinetic energy
[itex]T=\frac{1}{2}mv^2[/itex]
this means that the final velocity is 34, based on the final kinetic energy given in the back of the book. Which is far different from the final velocity of 86.39 that I get. Where am I going wrong?
Note: I have not tried to do part c yet, this is just focused on part b.
