Baseball in the air 2D motion question
A baseball is hit vertically with an initial speed of 27 m/s, reaching a maximum height of approximately 37.32 meters and staying in the air for about 2.76 seconds, assuming negligible air resistance. When caught, the player's glove moves downward by 12 cm, which requires calculating the acceleration of the ball during this brief catching phase. The discussion highlights that the kinematic equations used for constant acceleration do not apply during the catching process, as the acceleration changes upon impact. It is suggested that the catching phase should be treated separately, and the acceleration during this phase is not simply 9.8 m/s² due to the glove's motion. Understanding the distinction between the ball's flight and the catching dynamics is crucial for accurate calculations.
Kyros
A baseball is hit into the air, nearly vertically, with a speed of 27 m/s. When it comes down, the ballplayer catches it in his glove. Air resistance (drag) is actually fairly important for a baseball in flight, but for now let’s assume it is negligible.
(a) How high does the baseball go, and how long is it in the air?
(b) As the player catches the ball, his glove moves downward by 12 cm before coming to rest. Based on this, estimate the acceleration of the ball as it is caught.
Variables:
V=27 m/s
Acceleration= g= 9.8
Vo= 0 m/s
Xo=0 m
x=?
t=?
kinematic equations for constant acceleration:
V=Vo+at
X=X0+V0t+1/2at^2
V^2=Vo^2+2a(X-Xo)
Average V= (V+Vo)/2
v= change in x/ change in t
a= change in v/change in t
[/B]
a.
V= Vo+(at)
27= (0)+ 9.8t
t= 2.76 seconds
X=Xo+Vot+1/2at^2
x=(0)+(0)(2.76)+1/2(9.8)(2.76)^2
x=37.32m
b.
this is where i get lost...
12cm= .12m
x= 37.32 +.12m = 37.44m
t= 2.76 seconds
v= 37.44 /2.76 = 13.57m/s
a= 13.57m/s/2.76
a= 4.92Thats my attempt, I'm really lost so any advice or help will be appreciated. I'm not too confident about my answer but a too. Also, is b just 9.8? since its just gravity acting on the ball.
Not sure if you understood this. It is asking for the acceleration from the moment the ball touches the gloves until it comes to rest.
Adding the two distances is not useful. The kinetics equations you use ("SUVAT") only apply while the acceleration is constant. When the gloves make contact, the acceleration changes.
Treat the process of catching as entirely separate.
There is a small flaw in the statement of the question. It ought to tell you to assume this catching acceleration is constant.
  • · Replies 20 ·
  • · Replies 16 ·
