Basic band theory question, free electron model
In summary, according to the author, the width of a band in a one dimensional lattice is determined by the energy difference between two consecutive states.
pierce15
315
Hello,
I am trying to figure out the width of bands in a 1-dimensional lattice. Here is a short derivation from the book I am reading: if we approximate the free electrons as being in a square well then the energy levels are ## \frac{\pi^2 \hbar^2 n^2}{2mL^2}##. If there are ##N## ions separated by a distance ##a## in the metal, then ##N = L/a##. The number of energy levels in the band is ##N##, so $$E_\text{max} \approx \frac{\pi^2 \hbar^2 N^2}{2mL^2} = \frac{ \pi^2 \hbar^2}{2 ma^2},$$
since the lowest energy is nearly 0. Thus, the width of the band depends not on ##N##, but on ##a##.
I'm a bit confused about what the calculation actually says. My understanding was that there are many bands, and that the energy width of each successive band increases. Is this the calculation for the width of the lowest energy band? Or is this just a nonsense derivation?
Thank you for the help. In case you are curious, the source is Eisberg and Resnick, Quantum Physics of Atoms, Molecules, Solids, Nuclei, and Particles, which I have found to be a good source for nearly everything except results requiring math. (In fact, nearly every calculation requiring more than a page is relegated to a ~100 page long appendix.)
pierce15 said:
If there are NNN ions separated by a distance aaa in the metal, then N=L/aN=L/aN = L/a. The number of energy levels in the band is NNN, so
Emax≈π2ℏ2N22mL2=π2ℏ22ma2,Emax≈π2ℏ2N22mL2=π2ℏ22ma2,​
since the lowest energy is nearly 0. Thus, the width of the band depends not on NNN, but on aaa.
in one dimensional lattic the quantized momentum k=( 2.Pi/L) n , therefor this n=0, 1,2,...+N/2 and -1,-2,...-N/2
so the width will be the energy difference between two consecutive states..
check in your expression n and N are identical or not.
This is for free electron (Fermi) gas in a box. There is no band structure in this model. You need to introduce interaction with lattice for that.
In this model (free electrons) you have energy levels (not bands), given by that formula, with various values of n.
What you have there is the highest energy level occupied by an electron, at zero Kelvin. It is called the Fermi energy.
If you want, you can consider all these levels as forming a band.
The value of this energy depends on the electron density (for 1D is just N/L) but you can write this density in terms of the lattice constant, as you did here.
Ah, I see. Thanks.
FAQ: Basic band theory question, free electron model
What is the basic band theory?
The basic band theory explains the electronic structure of solids, specifically the movement of electrons within a crystal lattice. It is the foundation of modern condensed matter physics.
What is the free electron model?
The free electron model is a simplified model used to describe the behavior of electrons in a solid. It assumes that the electrons are free to move throughout the entire crystal lattice, and their energy levels form a continuous band.
What is the significance of the free electron model in band theory?
The free electron model serves as a starting point for understanding the electronic properties of solids. It helps to explain the concept of energy bands and how they relate to the conductivity and other properties of materials.
Can the free electron model accurately describe all materials?
No, the free electron model is an idealized model and does not accurately describe the behavior of all materials. It does not take into account the effects of the crystal lattice on the movement of electrons, and therefore cannot accurately explain the properties of insulators and semiconductors.
How does the free electron model relate to the quantum mechanics of electrons?
The free electron model is a simplified version of the quantum mechanical model of electrons. It uses the concept of energy bands to explain the behavior of electrons in a solid, while the quantum mechanical model takes into account the wave-like nature of electrons and their interactions with the crystal lattice.
