Basic derivation of Lorentz Transformation
In summary: This is where Einstein's Eq 5 comes in.Einstein's Eq 5 states that the line x=xo+vt is a parallel line in [x,t] coordinates, and that the equation for that line is x=xo+L+vt.
ben.g95
Hey, I'm just learning the ins and outs of special relativity and I'm having a little trouble with the derivation of the Lorentz Transformation. I bought Einstein's book 'Relativity: the special and general theories' and this is described in an appendix. For background, the appendix is linked to at the bottom of this post. (It was posted on marxists.org, I found that pretty funny, even though I knew Einstein was a socialist.) I get lost between
(x'+ct')=μ(x+ct) and
a=(λ+μ)/2
Also, looking ahead, I've gotten lost before (this isn't my first time looking over the appendix, I lost my work from last time, though) between
dx=1/a
and x'=a(1-(v2)/c^2))x <-- this one I really can't get (how does he get there?)
If anyone could be of any help, thanks!
http://www.marxists.org/reference/archive/einstein/works/1910s/relative/ap01.htm
ben.g95 said:
I get lost between
a=(λ+μ)/2[/url]
In defining the mathematical forms of Eq 3 & 4, he sets up the unknown constants λ and μ. The problem then is to determine them.
Instead of determining λ and μ directly, he will determine them indirectly by determining a=(λ+μ)/2 and b=(λ-μ)/2 first.
How did he plug in constants a and b to obtain formulas (5)?
From a=(λ+μ)/2 and b=(λ-μ)/2, we get a+b=λ and a-b=μ.
When plugging in a and b, I keep getting x'=ax-act and ct'=bx+bct and getting stuck there. I'm a beginner at this, could you walk me through it (thanks for being patient)? I feel like I'm close but I don't know where to go next.
By definition:
a=(λ+μ)/2
b=(λ-μ)/2
Adding the two equations gives: a+b=λ, ie. λ=a+b
Subtracting the two equations gives: a-b=μ, ie. μ=a-b
Now we know λ and μ in terms of a and b.
So x'-ct'=λ(x-ct) becomes:
x'-ct'=(a+b)(x-ct)
x'-ct'=ax+bx-act-bct (Eq I)
And x'+ct'=μ(x+ct) becomes:
x'+ct'=(a-b)(x+ct)
x'+ct'=ax-bx+act-bct (Eq II)
If I add Eq I and Eq II, the left hand side (LHS) is x'-ct' + x'+ct' = 2x'.
If I add Eq I and Eq II, the right hand side (RHS) is ax+bx-act-bct + ax-bx+act-bct = 2ax-2bct.
Equating LHS and RHS gives 2x'=2ax-2bct.
So x'=ax-bct, which is the first of Einstein's Eq 5.
Is that ok so far?
That was great! You are a physics god among men.
Now on to the tougher stuff (for me at least).
Where does he get dx=1/a from?
I'm a biologist.
I don't follow his reasoning either! Is it correct?
I'm not really sure... it seems to come up in the next term (lost on that one as well), but I don't know what hat he pulled it out of.
OK, it's correct. Will post an explanation later.
Good, I couldn't get anywhere with it.
I don't mean to sound like a jerk here, but could you please post your progress? Thanks.
I haven't been able to simplify Einstein's explanation, am still working on it.
But there are many others here who presumably can.
Let's say we have a rod of length L' moving with constant velocity u with respect to [x',t'] spacetime coordinates. Its left and right ends will trace out parallel lines of spacetime points described by equations of the form x'=xo'+ut' and x'=xo'+L'+ut'. In the particular case that the rod is stationary with respect to [x',t'] spacetime coordinates, u=0, and the parallel lines are x'=xo' and x'=xo'+L'.
Substituting Einstein's Eq 5 into parallel lines x'=xo' and x'=xo'+L', we get xo'=ax-bct and xo'+L'=ax-bct, which we can rearrange to x=(xo'+bct)/a and x=(xo'+L'+bct)/a to see more clearly that they are parallel lines in [x,t] coordinates. These parallel lines have the form x=xo+vt and x=xo+L+vt, as expected for the left and right ends a rod of length L moving with velocity v with respect to [x,t] coordinates, with xo=xo'/a, L=L'/a and v=bc/a. The equation L=L'/a is Einstein's Eq 7.
Let us note that since the rod was stationary in [x',t'] coordinates, and moving with velocity v=bc/a in [x,t] coordinates, v is also the velocity of [x,'t'] coordinates with respect to [x,t] coordinates. Hence our equation v=bc/a is Einstein's Eq 6.
Where did you get xo=xo'/a and L=L'/a? I follow you completely minus those two.
Compare these two equations from post #14.
1) The equation for the spacetime line traced out by the right end of the rod obtained by getting the equation in [x',t'] coordinates then transforming to [x,t] coordinates:
x=(xo'+L'+bct)/a
2) The equation for the spacetime line traced out by the right end of the rod in [x,t] coordinates, obtained by the definition that it is a rod moving with velocity v with respect to [x,t] coordinates:
x=xo+L+vt
These two equations describe the same thing, so they must be the same equation, which will be the case only if xo=xo'/a, L=L'/a and v=bc/a
From x' = ax → Δx' = a Δx
But I = Δx', therefore I = a Δx, or Δx = I/a
Hope it helps.
FAQ: Basic derivation of Lorentz Transformation
What is the Lorentz Transformation?
The Lorentz Transformation is a mathematical equation that describes the relationship between space and time in Einstein's theory of special relativity. It allows us to calculate how measurements of space and time change for an observer moving at a constant velocity relative to another observer.
Why is the Lorentz Transformation important?
The Lorentz Transformation is important because it helps us understand how the laws of physics must be modified when objects are moving at high speeds. It also provides the foundation for Einstein's theory of special relativity, which has been confirmed by numerous experiments and is essential for our understanding of the universe.
How is the Lorentz Transformation derived?
The Lorentz Transformation is derived from two main postulates: the principle of relativity, which states that the laws of physics are the same for all observers in uniform motion, and the constancy of the speed of light, which states that the speed of light is the same for all observers regardless of their relative motion. By combining these two postulates and using mathematical equations, we arrive at the Lorentz Transformation.
What are the basic equations of the Lorentz Transformation?
The basic equations of the Lorentz Transformation are:
x' = (x - vt)/√(1-v²/c²)
t' = (t - vx/c²)/√(1-v²/c²)
Where x and t are the measurements of space and time in the stationary frame, x' and t' are the measurements in the moving frame, v is the relative velocity between the two frames, and c is the speed of light.
What are the practical implications of the Lorentz Transformation?
The Lorentz Transformation has many practical implications, including the understanding of time dilation, length contraction, and the relativity of simultaneity. It also plays a crucial role in fields such as particle physics, where high speeds are involved, and in the development of technologies such as GPS. Additionally, the Lorentz Transformation helps us understand the fundamental nature of space and time and how they are interconnected.
