Basic Derivation with negative exponents
In summary, the conversation discusses the use of Thompson's Calculus Made Easy to learn calculus and specifically, the concept of negative exponents. The conversation also mentions online resources such as Purplemath and Algebrahelp for further explanation. The main focus of the conversation is on the binomial theorem, its validity for various values of n, and how it can be simplified using the definition of nCr. Additionally, the conversation mentions the use of Newton's Generalized Binomial Formula for fractions and negative numbers.
fyamnky
Hello reader
So I'm trying to teach mysel calculus with Thompson's Calculus made easy.
I'm still in the very early stages and I got stuck with negative exponents.
I'd basically like an explanation fof what's going on here.
http://www.flickr.com/photos/26906498@N03/3705112800/
I've tried using online sources like:
http://www.purplemath.com/modules/exponent.htm
http://www.algebrahelp.com/lessons/simplifying/negativeexponents/
I also looked up Binomial Theorem on wikipedia which just confused me more.
http://en.wikipedia.org/wiki/Binomial_theorem
Well basically, the binomial theorem is valid for only n being an integer such that
[tex](a+b)^n = b^n +^nC_1 b^{n-1}a + ^nC_2 b^{n-2}a^2 +...+ ^nC_r b^{n-r}a^r + a^n[/tex]
But if you use the definition of nCr being n!/(n-r)!r!. Then terms like nC1 works out as
[tex]^nC_1 = \frac{n!}{(n-1)!1!} = \frac{n(n-1)!}{(n-1)!}=n[/tex]
[tex]^nC_2 = \frac{n!}{(n-2)!1!} = \frac{n(n-1)(n-2)!}{(n-1)!2!}= \frac{n(n-1)}{2}[/tex]
So (a+b)n simplifies to this
[tex](a+b)^b = b^n + nb^{n-1}a + \frac{n(n-1)}{2!}b^{n-2}a^2 + \frac{n(n-1)(n-2)}{3!}b^{n-3}a^3 + ...[/tex]
so if ever you put n as a negative number or a fractional number then you'd have an infinite number of terms which is valid for |b/a| < 1.
so in the chapter, the expansion is valid for
[tex]\left | \frac{dx}{x} \right | < 1 \Rightarrow -1< \frac{dx}{x}<1[/tex]
or simply dx/x is small, that is why they neglected the terms after x-3
EDIT: Normally you won't need to do the y+dy = x +dx thing always, you can just usually apply y=xn => dy/dx=nxn-1
rockfreak667, if you go down far enough on the wikipedia page cited, you find "Newton's Generalized Binomial Formula" which does NOT require positive integers.
For any non-negative integers, n and m, [itex]n\ge m[/itex]
[tex]\left(\begin{array}{c}n \\ m\end{array}\right)= \frac{n!}{m!(n-m)!}= \frac{n(n-1)(n-2)\cdot\cdot\codt\(n-m+1)}{m(m-1)(m-2)\cdot\cdot\cdot(3)(2)(1)}[/tex]
In that final form, we can, in fact, write it out for n and m any numbers, not just non-negative integers. Of course,
[tex]\left(\begin{array}{c} n \\ n\end{array}\right)= 1[/itex]
and
[tex]\left(\begin{array}{c}n \\ n-1\end{array}\right)= n[/itex]
for any n, non-negative integer or not. Thus, we can write
(x+ h)n= (1)xn+ (n)x{n-1}h+ terms involving h2 or higher, for any number n, positive integer or not. Then, (x+h)n- xn= n xn-1h+ terms involving h2 or higher and, dividing by h, [(x+h)n- xn]/h= n xn-1+ terms involving h or powers of h. Taking the limit as h goes to 0, all those "terms involving h or powers of h" go to 0 leaving only nxn-1.
That's how I learned the binomial theorem, first with n being a positive integer and then the generalized form for fractions and negative numbers. Most likely due to working out 50C34 and such we just used a calculator instead of writing it out...things like -3C1 on a calculator would make me go :bugeye:
FAQ: Basic Derivation with negative exponents
What is a negative exponent?
A negative exponent is a way of representing a fraction with a denominator greater than the numerator. It is written as a^-n, where a is the base and n is the negative exponent.
How do you solve a basic derivation with negative exponents?
To solve a basic derivation with negative exponents, you can use the power rule which states that a^-n = 1/a^n. This means that you can rewrite the fraction with a positive exponent and then apply the usual rules of derivation.
What is the difference between a negative exponent and a positive exponent?
A positive exponent indicates how many times a number is multiplied by itself, while a negative exponent indicates how many times a number is divided by itself. In other words, a positive exponent represents repeated multiplication, while a negative exponent represents repeated division.
Can negative exponents be used with variables?
Yes, negative exponents can be used with variables. The same rules for solving negative exponents apply, where a variable raised to a negative exponent can be rewritten as 1/variable raised to the positive exponent.
Why do we use negative exponents in mathematics?
Negative exponents allow us to represent fractions in a more concise way and make certain calculations easier. They are also commonly used in scientific notation to represent very small numbers.
63K
