Basic Electric Field in Conductor Principles
In summary, the net charge on the wall of a conductor's cavity with a point charge inside it must be -q, and the net charge on the outer surface is Q0 + q. The reason for this is that a conductor can only carry charge on its surface boundaries and the field lines in the cavity must start at the point charge and terminate on the cavity wall. This is due to the fact that the closed integral of the dot product is zero and the E field must be perpendicular to the metallic surface, which is an equipotential.
FallenLeibniz
86
The following is a small concept exercise from an. EM text (Electromagnetism: Pollack and Stump). I believe I have the explanations correct, but am just looking for "peer-review" as they seem "hand-wavy":
Suppose a conductor has a cavity inside it, and there is a point charge q somewhere in the cavity. Prove that the net charge on the wall of the cavity must be -q. If the net charge of the conductor is Q0[\SUB], what is the net charge on its outer surface? Why must every field line in the cavity begin on q and on the cavity wall? (Hint: For the last statement, use the fact that ##\oint\vec{E}\cdot d\vec{l}## )
[/B]Other than the one in the statement of the problem, nothing really as it is a concept question more than anything.
a) [/B]Let ##\vec{E}_{int}## be the field inside the conductor material (which is of course ##\vec{0}##). Let S be a gaussian surface that is large enough to both enclose the cavity and a small portion of the conductive material. Since ##\vec{E}_{int}\cdot d\vec{A}## at S is zero, it follows from Gauss's Law that the enclosed charge is zero. Taken with the fact that a conductor may have no overall charge density inside itself when in equilibrium except at surface boundaries, the wall must have -q.
b) ##Q_0## +q. As before stated, a conductor may only carry charge on its surface boundaries. Since we have established that -q is on one boundary inside the conductor, ##Q_0## +q must be on the outside for the net charge of the conductor to be ##Q_0## only. Note that this also finds validity when considering an empty cavity.
c) To start, a field must have a source. Since the only source for the field in the cavity is the charge, it must start there. Note that the fact that the closed integral of the dot product is zero means that any field that meets the boundaries of a curve must do so perpendicularly. Now the field can not terminate inside the cavity since it can not just arbitrarily terminate in mid air and the field can not travel through or terminate in the conductor since the internal conductor field must be zero. Thus the field must terminate on the cavity boundary.
(a) Suppose a conductor has a cavity inside it, and there is a point charge q somewhere in the cavity. Prove that the net charge on the wall of the cavity must be -q.
(b) If the net charge of the conductor is Q0, what is the net charge on its outer surface?
(c) Why must every field line in the cavity begin on q and on the cavity wall? (Hint: For the last statement, use the fact that ##\oint\vec{E}\cdot d\vec{l}## = 0. )
I've rewritten your problem statement slightly for clarity.
I agree with (a) and (b) and am not sure of (c), especially the statement that " ... the fact that the closed integral of the dot product is zero means that any field that meets the boundaries of a curve must do so perpendicularly." That integral is zero anywhere in an electrostatic environment. The reason the E field is perpendicular to the metallic surface is that the metallic surface is an equipotential and the E field is always perpendicular to the equipotential surface. The rest of your statement sounds right. Maybe someone else will comment more on this.
Related to Basic Electric Field in Conductor Principles
What is an electric field in a conductor?
An electric field in a conductor is a region in which electric charges experience a force. In a conductor, the electric field is created by the presence of free electrons that are able to move throughout the material.
What is the principle of a basic electric field in a conductor?
The principle of a basic electric field in a conductor is that the electric field inside a conductor is zero. This means that the charges in a conductor will always distribute themselves in such a way that the electric field inside the conductor is cancelled out.
How does a conductor maintain a constant electric field?
A conductor maintains a constant electric field by allowing free electrons to move through the material. When an external electric field is applied, the free electrons will move in response, creating an opposite electric field that cancels out the external field. This ensures that the electric field within the conductor remains constant.
What is the role of the shape of a conductor in its electric field?
The shape of a conductor plays a crucial role in its electric field. In a conductor, the electric field is strongest at sharp edges and points, so the shape of the conductor can affect the distribution of charges and the strength of the electric field within the material.
How does the presence of charges affect the electric field in a conductor?
The presence of charges in a conductor is what creates the electric field. As charges move or accumulate within the conductor, the electric field is affected and the charges will redistribute in order to maintain a constant electric field within the material.
