Basic Math Problem of the Week 10/28/2017
  • Challenge
  • Thread starter PF PotW Robot
In summary, the problem is to prove that for the quadratic equation ##x^2-kx+2n=0##, one of the roots is equal to ##\dfrac{1}{\sqrt{1}}+\dfrac{1}{\sqrt{2}}+\cdots+\dfrac{1}{\sqrt{n}}##, where ##n## is a positive integer. The task is to prove that ##2\sqrt{2n} \le k \le 3\sqrt{n}##. A hint is given to use the distance between the minimum and zero of the parabola and a solution by @QuantumQuest is provided with a minor correction. The series ## S_n ## is discussed and
PF PotW Robot
Here is this week's basic math problem. We have several members who will check solutions, but we also welcome the community in general to step in. We also encourage finding different methods to the solution. If one has been found, see if there is another way. Using spoiler tags is optional. Occasionally there will be prizes for extraordinary or clever methods.
One of the roots of the quadratic equation ##x^2-kx+2n=0## is equals to ##\dfrac{1}{\sqrt{1}}+\dfrac{1}{\sqrt{2}}+\cdots+\dfrac{1}{\sqrt{n}}##, where ##n## is a positive integer.
Prove that ##2\sqrt{2n} \le k \le 3\sqrt{n}##
(PotW thanks to our friends at http://www.mathhelpboards.com/)
Likes Charles Link
Hint for the difficult part: Try to use the distance between the minimum and the zero of the parabola, ##S_n := \dfrac{1}{\sqrt{1}}+\dfrac{1}{\sqrt{2}}+\cdots+\dfrac{1}{\sqrt{n}}## for the estimation.
Likes Greg Bernhardt
Just an idea for the right part of the inequality to be proved
Let ##x_1## and ##x_2## be the roots of the given quadratic equation with ##x_1 =
Using Vieta's formulas for quadratics (##ax^2 + bx + c = 0##) and applying to the given quadratic equation we have that ##x_1 + x_2 = -\frac{b}{a} = k## and ##x_1\cdot x_2 = \frac{c}{a} = 2n##. So, ##x_2 = \frac{2n}{\dfrac{1}{\sqrt{1}}+\dfrac{1}{\sqrt{2}}+\cdots+\dfrac{1}{\sqrt{n}}}##. Now, going to the inequality we're asked to prove we substitute ##k## for the sum of the two roots ##x_1 + x_2## and we have
##\dfrac{1}{\sqrt{1}}+\dfrac{1}{\sqrt{2}}+\cdots+\dfrac{1}{\sqrt{n}} + \frac{2n}{\dfrac{1}{\sqrt{1}}+\dfrac{1}{\sqrt{2}}+\cdots+\dfrac{1}{\sqrt{n}}} \leq 3\sqrt{n}##.
Now, to prove this right part of the asked inequality, we utilize that ##\dfrac{1}{\sqrt{1}}+\dfrac{1}{\sqrt{2}}+\cdots+\dfrac{1}{\sqrt{n}} < 2\sqrt{n}##. This can be easily proved using induction, so I omit the proof here. Returning to the right part of the asked inequality and doing the math we have
##\frac{(\dfrac{1}{\sqrt{1}}+\dfrac{1}{\sqrt{2}}+\cdots+\dfrac{1}{\sqrt{n}})^2 + 2n}{\dfrac{1}{\sqrt{1}}+\dfrac{1}{\sqrt{2}}+\cdots+\dfrac{1}{\sqrt{n}}} \leq \frac{6n}{2\sqrt{n}} = 3\sqrt{n}## which is what is asked in the right part.
Likes Charles Link, fresh_42 and Greg Bernhardt
An excellent solution by @QuantumQuest ! I would like to make one minor correction though. In proving that ## S_n+\frac{2n}{ S_n} \leq 3 \sqrt{n} ##, I think in writing it as a fraction, you would need to have a lower limit on the denominator (rather than an upper limit) to prove the last "less than or equal" inequality. ## \\ ## Instead, let ## S_n=2 \sqrt{n}-\delta_n ##. Also let ## A=\sqrt{n} ##. Then we need to find the conditions on ## \delta_n ## so that ## 2A-\delta_n+\frac{2A^2}{2A-\delta_n} \leq 3 A ##. Multiplying through on both sides by ## 2A-\delta_n ##, we get ## (2A-\delta_n)^2+2A^2 \leq (3A)(2A-\delta_n) ##. The result after a little algebra ( multiplying out, and subtracting, etc.) is ## \delta_n \leq A ##. Thereby ## \delta_n \leq \sqrt{n} ## is the requirement for the inequality to hold. For the series ## S_n ##, when ## n=1 ##, ## \delta_1=1 ## . For integers ## n>1 ##, it looks as if it will clearly be the case that ## \delta_n <\sqrt{n} ##, but on this part (for ## n>1 ##), I will forego a rigorous proof.
Likes QuantumQuest and Greg Bernhardt
Related to Basic Math Problem of the Week 10/28/2017
1. What is the "Basic Math Problem of the Week" for 10/28/2017?
The Basic Math Problem of the Week for 10/28/2017 is a specific math problem that is given to students or participants to solve within a week's time. It is usually a basic math question that tests their understanding of fundamental concepts.
2. Who can participate in the "Basic Math Problem of the Week"?
Anyone can participate in the Basic Math Problem of the Week, as long as they have the necessary math skills to solve the given problem. It is often used as a fun and engaging way to practice math and improve problem-solving skills.
3. How is the "Basic Math Problem of the Week" selected?
The Basic Math Problem of the Week is usually selected by a team of math experts or educators. They choose a problem that is challenging but also appropriate for the target audience. The problem may also be related to current events or holidays.
4. Is there a prize for solving the "Basic Math Problem of the Week"?
This may vary depending on the organizer, but there may be a prize for solving the Basic Math Problem of the Week. It could be a small reward or recognition, such as a certificate or a mention on a website. The main goal, however, is to encourage learning and critical thinking skills.
5. Can I use a calculator to solve the "Basic Math Problem of the Week"?
Again, this may depend on the organizer, but most Basic Math Problems of the Week are designed to be solved without a calculator. This is to test and improve mental math skills. However, some organizers may allow the use of a calculator for certain problems.
  • Math Proof Training and Practice
