Basic matlab q on writing error messages
In summary, error messages can be written in Matlab for when a function is given an illogical input by either printing a string or using the MException function to handle errors.
brandy
161
How do you write error messages
for when a function has been given an input that is illogical for what the function does.
in matlab
function b = bla(a)
for example if a < 0
i want it to display a message
You could do something as basic as printing a string when the error occurs, e.g.:
Code:
[COLOR="Blue"]function[/COLOR] [output] = myfun(input)
    [COLOR="SeaGreen"]% do stuff[/COLOR]
    [COLOR="blue"]if[/COLOR] someCondition < minValue [COLOR="SeaGreen"]% define error condition however you need it[/COLOR]
         fprintf([COLOR="Indigo"]'Error: invalid input. Input must be between foo and bar!\n'[/COLOR]);
         [COLOR="blue"]return[/COLOR];
    [COLOR="blue"]end[/COLOR]
[COLOR="Blue"]end[/COLOR]
A better way would be to http://www.mathworks.com/help/techdoc/matlab_prog/bq_jgj8-1.html" . This way, any code that calls the function can handle errors.
Code:
        err = MException([COLOR="Indigo"]'Myfun: Input Error'[/COLOR], [COLOR="Navy"]...[/COLOR]
                         [COLOR="Indigo"]'Myfun received bad input arguments.'[/COLOR]);
        throw(err);
Related to Basic matlab q on writing error messages
What is the importance of writing error messages in basic Matlab?
Writing error messages in basic Matlab is important because it helps in debugging and identifying errors in your code. It also helps in understanding the cause of the error and finding a solution to fix it.
What are the common mistakes to avoid when writing error messages in basic Matlab?
Some common mistakes to avoid when writing error messages in basic Matlab include using unclear or vague language, not providing enough information about the error, and not including suggestions for how to fix the error.
How can I create custom error messages in basic Matlab?
To create custom error messages in basic Matlab, you can use the "error" function and specify the type of error and the message you want to display. You can also include variables or other information in the error message to provide more context.
What is the difference between a warning and an error message in basic Matlab?
A warning message in basic Matlab indicates that there may be a potential issue with your code, but it will still run. An error message, on the other hand, means that your code cannot be executed and needs to be fixed before it can run.
How can I handle errors in my code using try-catch blocks in basic Matlab?
To handle errors in your code, you can use a "try-catch" block in basic Matlab. This allows you to specify which parts of your code should be executed if an error occurs, and what actions should be taken to handle the error.
