Basic Mechanical Engineering Help Required
In summary, Adam is new to mechanical engineering and is struggling with the ICS distance learning course. He has attached a picture of a problem he is having with the course tutor. He asks for help explaining how to answer a question on the homework, and any help would be much appreciated.
sperrya
Hi there, hoping someone can help me. I am studying ICS distance learning course and, well to be honest am getting no support whatsoever from the course tutor AND have discovered lots of mistakes in their learning modules. I have no faith in them now whatsoever! However, I need to complete the following questions, but am struggling... ANY help to explain how I answer the following questions will be much appreciated! I have attached a picture of the initial problem.
Q1. Calculate the component of the force that is acting horizontally on the crate
Q2. State the effect the force has on the line connecting the crate to the motor
Q3. Each crate has a mass of 200kg, calculate the acceleration experienced by each crate
Q4. The distance covered by each crate is 20m. Assuming that each crate starts at rest, calculate the speed of each crate at the end of the 20m journey
Q5. Calculate the kinetic energy of the crate at the end of the journey
Q6. Calculate the duration of the journey
Q7. Calculate the work done on the crate during the journey
Q8. Calculate the change in momentum of each crate
See below.
I have attempted some of the questions as follows:
Q1. 500Cos15 = 482.96N
Q2. The force increases the tension on the line connecting the crate to the motor and pulls the crate across the floor
Q3. a=F/M so a=500/200, therefore a=2.5ms-2
Q4.
Q5.
Q6.
Q7. WD=F x S, so 482.96 x 20 = 9659.2 Joules
Q8.
Any help would be much appreciated, especially Q4..
Thanks in advance.
Adam (new to mechanical engineering and learning!)
See below.
Q4.
Q5.
Q6.
Q8. Any help would be much appreciated, especially Q4..
Thanks in advance.
Q3. the horizontal component [Q1] is causing the acceleration not the full 500N
Q4 - Q8 you should be applying the usual equations of motion, Newtons laws and expressions for Kinetic Energy and Momentum
So, does this look right..??
Q3. a=F/M so a=482.96/200, therefore a=2.415ms-2
Q4. v=2s/t, therefore v=2.42ms-1
Q5. KE=1/2MV2, therefore KE=585.64 Joules
Q6. V=U+at, therefore duration is 16.56 seconds
Q8. Momentum=MV, therefore 200 x 2.415 = 483kgms-1
Your help/guidance would be much appreciated. The material ICS supplied has been teaching me the wrong principles so forgive me if I seem confused over what seems easy questions.
Thanks
i beg to differ...
Q1. 482.96N
Q2. same
Q3.2.415ms-2
Q4... i have a different answer to sperrya's...
i used the formula V²= U² + 2as (in the course notes)
which results in an answer of 9.818m-1
You're not the only one who is confused!
I, unfortunately, am doing the same course! I wish I had done more research into ICS course material first, full of mistakes and missing info.
I have different answers from Q4 on...
Q4 - 9.82 ms-1
Q5 - 9.64 kJ
Q6 - 4.07 seconds
Q7 - 9659.20 J
Q8 - 1,964 kg ms-1
Q9 - 6.547 kN
FAQ: Basic Mechanical Engineering Help Required
What is basic mechanical engineering?
Basic mechanical engineering is a branch of engineering that deals with the design, construction, and operation of machinery. It involves the principles of mechanics, thermodynamics, and materials science to create solutions for various mechanical problems.
What are some common applications of basic mechanical engineering?
Basic mechanical engineering has a wide range of applications, including the design of machines and mechanical systems, manufacturing processes, and control systems. It is also used in industries such as automotive, aerospace, and robotics.
What are the fundamental concepts of basic mechanical engineering?
The fundamental concepts of basic mechanical engineering include mechanics (statics and dynamics), thermodynamics, materials science, fluid mechanics, and control systems. These concepts are essential for understanding the behavior of mechanical systems and designing efficient solutions.
What skills are required for basic mechanical engineering?
Basic mechanical engineering requires a strong foundation in mathematics, physics, and computer-aided design (CAD). It also requires critical thinking, problem-solving, and communication skills. Practical skills such as welding, machining, and fabrication are also beneficial.
How can I get help with basic mechanical engineering?
There are many resources available for getting help with basic mechanical engineering. You can consult textbooks, online tutorials, and engineering forums. It is also helpful to seek guidance from experienced engineers or attend workshops and seminars. Additionally, many universities offer basic mechanical engineering courses and have support services for students.
