Basic Motion Problem (Dropping Objects)
  • Thread starter doug1
  • Tags
    Motion
In summary, to evenly space the sound of five rocks hitting the ground using a length of rope, you must attach a rock at the top and bottom of the rope. Using kinematics equations, the distances between each rock can be calculated by rearranging equations in terms of the time interval between each rock's impact. The total length of the rope can then be determined by subtracting the distances between the top and bottom rocks.
doug1
You are given a length of rope, tape and five rocks. The rocks must be attached in such a manner that when the rope is released, the sound of each rock hitting the ground is evenly spaced.
There must be a rock at the very bottom and the very top of the rope. When the rope is released, the bottom rock will be just above the ground. A stopwatch cannot be used (time cannot be recorded).
Any of the following kinematics equations:
d=1/2(Vf+Vi)t
Vf=Vi+at
d=Vit+1/2at^2
d=Vft-1/2at^2
Vf^2=Vi^2+2ad
a.) I understand that the rope will accelerate downwards due to gravity. This means that the rock at the top of the rope will have a faster final velocity just before impact than the rock at the bottom of the rope.
b.) Assuming that the bottom rock takes 0.1s to hit the ground I made the following calculations:
(Trying to space the sounds 0.2 second apart):
2nd rock from the bottom:
d = Vit+1/2at^2
d = (0)t + 1/2(9.81m/s^2)(0.3s)^2
d = 0.44 m
This means the second rock will be placed 0.44 m from the first rock (0.44 m from the bottom of the rope).
3rd rock from the bottom:
d = Vit+1/2at^2
d = (0)t + 1/2(9.81m/s^2)(0.5s)^2
d = 1.23 m
This means that the third rock will be placed 1.23 m from the bottom of the rope.
Is this the correct approach?
Close but you are given the length of rope so the distances have to add up to that length. Hard to do it that way.
Perhaps write equations for dtop and dbot in terms of Δt. where Δt = one time interval.
The length of the rope is then dtop - dbot. Rearrange to give Δt ?
Something like that.
Related to Basic Motion Problem (Dropping Objects)
1. What is basic motion problem (dropping objects)?
Basic motion problem (dropping objects) is a type of physics problem that involves the motion of an object that is dropped from a certain height and falls under the influence of gravity.
2. What is the formula for calculating the distance an object falls?
The formula for calculating the distance an object falls is d = 1/2 * g * t^2, where d is the distance, g is the acceleration due to gravity (9.8 m/s^2), and t is the time.
3. How does the mass of an object affect its falling motion?
The mass of an object does not affect its falling motion. All objects, regardless of their mass, will fall towards the ground with the same acceleration due to gravity.
4. What is the difference between free fall and air resistance?
Free fall is the motion of an object under the sole influence of gravity, while air resistance is the force that opposes the motion of an object through air. In free fall, there is no air resistance, but in real-life scenarios, air resistance can affect the motion of falling objects.
5. How can we calculate the time it takes for an object to hit the ground when dropped from a certain height?
The time it takes for an object to hit the ground when dropped from a certain height can be calculated using the formula t = √(2d/g), where t is the time, d is the distance, and g is the acceleration due to gravity.
