Basic probability, conditional probability
In summary, the probability that a component which is still working after 800 hrs, will last for at least 900hrs is 0.811023.
late347
301
what is the probability that a component which is still working after 800 hrs, will last for at least 900hrs
P(E|A) = ( P( E ∩ A) ) / ( P(A) )
Im just checking my own understanding if this problem is conditional probability or not.
I alraedy asked my teacher about the correct answer and I apparently had the correct answer.
But I was asked by my classmates to explain the answer, and I wasnt sure how deeply I understood the problem.
Looking at the table provided, we can see component lifetimes.
To my mind the problem can be translated into conditional probability terms such as:
"given that the component has lifetime from 800 upwards, what is probability that the component has lifetime from 900 upwards"
E : survive900hrsOrMore: (210+820) /1500 ==0,686666
A : survive800hrsOrMore: (210+820+240) /1500 == 0,846666
P(E|A) = P(E∩A) / P(A)
P(A) was calculated to be 0,846666
I think the probability of the intersection happening can be seen from the intersection in the following picture.
P(E∩A) was to my understanding calculated thusly:
(820+210)/1500 =0,686666
FavorableCases/ totalSampleSpace
in this case FavorableCases = 1030 parts that are inside the intersection
I don't know if this intersection probability can be calculated with a formula, but that seems to be how to calculate the probability of the intersection happening.
thus answer is
0,686666/ 0,846666= 0,811023
The way I would compute such a thing is to calculate a mean lifetime, if that is possible, and assume failures occur completely randomly and are not due to age. You can then write the probability that it will fail over a 100 hour period, basically as one minus an exponential of expected survival. ## \\ ## The alternative is to assume some quality factor and lower failure rate from the mean, because if it has survived for so long, it is one of those that simply doesn't fail. ## \\ ## This problem does appear to be somewhat subjective in the approach that is taken.
Looks fine to me.
I would strongly advice against this. You have a table with the appropriate observational information.
Likes scottdave and Charles Link
Orodruin said:
Looks fine to me.
Is the intersection probability such as P(E ∩A) correctly calculated? I was googling about that thing and I just became more confused by the fomrula I found. Something like "the general multiplication rule of probability"
The examples that we had in class were mostly about simple things like:
roll one die
event A: result is odd
event B: result is >=4
find P(A∩B)
in the intersection in the die case there is only 5.
Hence 1/6 is the probability
roll one die
find P(A∩B)
Initially I read the problem much too quickly. @Orodruin is correct. Alternatively you could simply have computed ##p= 1030/1270 ## and gotten the same answer. (The denominator of 1500 is present in both computations).
late347 said:
thus answer is
Yes, it all looks good. Just a couple of points that may or may not be interesting. The number of components that fail before 800 hours is irrelevant. Another way to look at it is that you have a reduced sample space. You know you are dealing with a component that lasts 800 hours or more, so your sample space has been reduced to those 1270 components. From that point of view you can do the calculation as a direct probability of 1030/1270.
(Which I see is what @Charles Link has just said.)
Likes Charles Link
Related to Basic probability, conditional probability
1. What is basic probability?
Basic probability is the measure of the likelihood of an event occurring. It is expressed as a number between 0 and 1, where 0 indicates impossibility and 1 indicates certainty.
2. What is the difference between theoretical and experimental probability?
Theoretical probability is based on mathematical calculations and assumes that all outcomes are equally likely. Experimental probability is based on actual observations and can vary depending on the sample size.
3. What is conditional probability?
Conditional probability is the likelihood of an event occurring given that another event has already occurred. It is calculated by dividing the probability of the two events occurring together by the probability of the first event occurring.
4. How is conditional probability used in real-life situations?
Conditional probability is used in various fields, such as medicine, finance, and weather forecasting, to make predictions and informed decisions. For example, a doctor may use conditional probability to determine the likelihood of a patient having a certain disease based on their symptoms and medical history.
5. How can one improve their understanding of probability?
One can improve their understanding of probability by practicing with various problems and scenarios, studying the basic principles and formulas, and seeking help from experts or taking courses in probability and statistics.
