Basic question about Scattering and understanding colors
In summary: Some visible light hitting the object is absorbed (and re-radiated as head - which you cannot see).The rest of the visible light is scattered ... the diffuse colour, what you are used to thinking of as the colour of the object, is the result of those wavelengths that get scattered off the surface.
Remixex
57
So I'm studying scattering and size parameters now, I've come to understand that the sky is blue because the size parameter is such that it's an excellent "scatterer" of blue-violet visible light, and horrible at red-orange, that let's pass, and such the sun is yellow within the Earth.
I've also come to understand why clouds are white, the parameter is such that it scatters all 7 discrete wavelengths of visible light, and by combining them it forms white.
But this generated a really basic, naive and almost innocent question in my head, how on Earth do big solid objects color work? My pen is huge, but it's blue, it's not because it's particles are small enough that it scatters blue better right?
I can't avoid feeling extremely stupid by asking this but i need to know, if color of really small particles is given by it's size, how come we have differently colored huge objects? Following the cloud's logic, shouldn't everything be white?
Science news on Phys.org
Solids get their colour from their molecular structure.
The rest of the visible light is scattered ... the diffuse colour, what you are used to thinking of as the colour of the object, is the result of thaose wavelengths that get scattered off the surface.
But you are correct, there is more to colour than the simple model you have.
Likes Remixex
No, not unless it's made of glass or something like that which can be solid and scatter light.
To absorb radiation at a given frequency there has to be a corresponding energy transition for a particle in the material. To emit radiation at a given frequency there also has to be a corresponding transition. This is a result of the photon energy equation ##E=\frac{hc}{λ}##. Quantum physics tells us that there can be a shortage of available states at some energy levels. There can even be complete voids at some energy levels. This is predicted by solutions of Schrodinger's equation inside the material. This calculation can be done for some crystals but in general is not easily accomplished.
If states are rare at certain energy levels then some transitions will be more common than others. That means a material can be better at absorbing some wavelengths and not so good at others. Likewise the material can be better at emitting some wavelengths when it is heated.
Likes Remixex
Remixex said:
[...] it scatters all 7 discrete wavelengths of visible light, [...]
Oh dear...
Likes davenn
Andy Resnick said:
Oh dear...
I googled that one and it appeared that, unless I read false information (which is usual on the internet), I did not invent or reach that conclusion by myself
Ok, thanks, solids get their color not from a size parameter, but from a "structure" parameter, so the wavelength range they scatter is given by that. :)
Can you please provide a link to the site that claims there are 7 visible wavelengths?
OK yes i get what you meant, i KNOW the wavelengths of visible light are within a range (700 to 400 nm was it?) i just tried to discretize them into the common 7 colors we see, sorry if you thought that was a huge mistake, i thought you meant something else.
Apparently, Newton himself saw and identified just six different colours but added a seventh because seven is a sexier number than six (more magically significant, apparently). Indigo / Violet? Who ever actually ever genuinely saw those two, except on a Dulux Paint shade card or in a darkened lab, after some adaptation time? :biggrin:
Likes Remixex
"indigo", was the added colour - it is the name of a plant that you get a kind of blue die from.
I always thought of it as a kind of product placement... though it was probably more because there was some sort of indigo fad on at the tie he was naming colours.
https://en.wikipedia.org/wiki/Indigo
otoh: magenta is, famously, a colour which does not correspond to a wavelength of light - which means we have to distinguish between the human experience of colour and the properties that give rise to them. Magenta is the eye/mind's response to the absence of green light from an otherwise reasonably white source, ie. it is an artifact of the functioning human visual system. The experience of magenta is what allows us to draw colour wheels when the electromagnetic spectrum does not work like that.
What I said about visible light also applies to non-visible light ... which is to say: the entire electromagnetic spectrum. However, the situation gets more complicated than just what colour something is. ie. gamma rays do scatter from matter ... but also do other things and can have nuclear interactions more than molecular or atomic ones. Questions about colour are usually more about the human visual system than it is about wavelengths anyway, I included this bit just to provide a glimpse into how big the subject can get.
The daft thing is that, when you look at the names for the colours on many CIE charts (Google Images "CIE colour space " and you get dozens of different versions of a coloured-in CIE chart) , violet is not placed on the spectral curve. Fact is, it's such a rare thing to see those far-end colours that it's a 'grey area' (pun intended). The most saturated colours we see regularly are on a TV screen and that has a very limited gamut of displayed colours..
I was interested to see a lack of the word "magenta" on many of those CIE charts. The world is going to hell in a handcart.
The idea of M(magenta) being -G(green), C(cyan) being -R(red) and Y(yellow) being -B(blue) is a source of confusion for the newcomer to Colour work.
It is not always necessary to invoke scattering to explain the color of objects. While in some cases there are pigments that scatter light, in other cases simple reflection, transmission and absorption are all that is needed. For example, a fiber that is dyed blue - white light enters the fiber, bounces around and gets redirected back to the observer. The red wavelengths have been absorbed so the fiber appears blue.
I should have said the red and green wavelengths have been absorbed.
Related to Basic question about Scattering and understanding colors
1. What is scattering?
Scattering is the process of redirecting light in different directions as it interacts with particles in a medium. This can result in different colors and brightness of light being observed.
2. How does scattering affect the perception of color?
The scattering of light can change the color of an object by selectively removing certain wavelengths of light and allowing others to pass through. This is why objects appear to have different colors depending on the lighting conditions.
3. What is the difference between Rayleigh and Mie scattering?
Rayleigh scattering is the scattering of light by particles that are much smaller than the wavelength of light, such as gas molecules. Mie scattering is the scattering of light by particles that are similar in size to the wavelength of light, such as water droplets or dust particles.
4. How does scattering contribute to the blue color of the sky?
The atmosphere contains gas molecules that are smaller than the wavelength of visible light. When sunlight enters the atmosphere, it is scattered in all directions by these molecules, with blue light being scattered more than other colors. This is why the sky appears blue to our eyes.
5. Can scattering be used for practical applications?
Yes, scattering is used in various technologies such as solar panels, optical fibers, and even in medical imaging techniques like ultrasound. Understanding scattering also helps in designing materials with desired optical properties.
  • Optics
  • Classical Physics
