Basic question: First derivative test to detect whether a function is decreasing
In summary, if the first derivative of a function f from R to R is negative on [a,b], it is correct to say that the function is decreasing on [a,b]. However, there are other ways to show that a function is decreasing on an interval, such as using the definition of decreasing or comparing values at different points on the interval.
seeker101
28
If the first derivative of a function f from R to R is negative on [a,b], it IS right to say that the function is decreasing on [a,b] right?
Are there any other ways of showing that the function is decreasing on [a,b]?
Mathematics news on Phys.org
Hi seeker101! :smile:
Yes.
No … for a differentiable R->R function, negative derivative at a point is the same as decreasing. :wink:
That's correct as a definition. But, what the OP is asking may be whether there are other ways of arguing that a function is decreasing over an interval.
Of course there are other ways to show a function is increasing (the same argument can be applied to decreasing) on an interval. For example, using the definition of increasing: if x,y are in [a,b] then show y > x implies f(y) >= f(x).
Example: Show that f(x) = x^2 is increasing on [0,2].
Let x and y belong to [0,2] with y > x. Then we can write y = x + e, for some e>0. Then f(y) = (x+e)^2 = x^2 + 2xe + e^2 > f(x) = x^2, since e^2 is >0 and 2xe is >0.
how about a function f is decreasing on [a,b] if [tex](\forall x_1,x_2\in [a,b])[/tex] [tex]x_1<x_2 \implies f(x_1) \ge f(x_2)[/tex]
Related to Basic question: First derivative test to detect whether a function is decreasing
1. What is the first derivative test?
The first derivative test is a mathematical method used to determine whether a function is increasing or decreasing at a specific point. It involves calculating the first derivative of the function and evaluating its sign at the point of interest.
2. How does the first derivative test work?
The first derivative test works by using the slope of the tangent line at a point on a function to determine the direction of the graph at that point. If the first derivative is positive, the function is increasing at that point, and if it is negative, the function is decreasing.
3. What is the purpose of using the first derivative test?
The first derivative test is useful for identifying critical points on a function, such as local maxima or minima, and determining the direction of the graph at those points. It can also be used to find the intervals where a function is increasing or decreasing.
4. Can the first derivative test be used to find the global maximum or minimum of a function?
No, the first derivative test can only be used to find local maxima or minima of a function. To find the global maximum or minimum, other methods such as the second derivative test or graphing the function may be necessary.
5. Are there any limitations to using the first derivative test?
Yes, the first derivative test can only be used for differentiable functions. It also may not work for functions with complex behavior, such as oscillations or discontinuities. In these cases, other methods may be needed to determine the behavior of the function at a specific point.
