Basic Related Rates: Rate of change of length of shadow
In summary, the problem involves finding the rate at which the shadow of a 6-ft man is increasing in length as he walks away from a 15-ft lamppost at a speed of 3 ft/s. The Pythagorean Theorem and the Theorem of Similar Triangles can be used to solve this problem, making the assumption that the man starts off 3ft away from the lamppost. A visual representation of the situation can be drawn to see the relationship between the man, his shadow, and the lamppost.
Michael_J
A 6-ft man walks away from a 15-ft lamppost at a speed of 3 ft/s. Find the rate at which his shadow is increasing in length.
Pythagorean Theorem, Theorem of Similar Triangles (ratios of corresponding sides are equal)
I am not actually not sure about how to start here. What confuses me is the shadow length; we know that the rate of change (or derivative) of the man's distance away from the lamppost is 3ft/s, but I am not sure where to go from here.
Help would gladly be appreciated.
You're allowed to make the assumption that he starts off from the same place with the lamp, so that he's exactly 3ft away from it after 1 second.
Start by drawing a picture. Draw the ground as a horizontal line, the lamp post as a vertical line, the man as a second, shorter, vertical line. The line from the tip of the lamp post to the tip of the man's head touches the ground at the tip of the shadow. You will see two similar (right) triangles there. The smaller has the height of the man as one leg, the length of his shadow as the other. Corresponding sides on the larger triangle are the height of the lamp post and the sum of the length of the shadow and the man's distance from the lamp post.
Related to Basic Related Rates: Rate of change of length of shadow
What is the concept of related rates?
The concept of related rates involves finding the rate of change of one quantity with respect to another related quantity. This is typically done by using derivatives and setting up an equation that relates the two quantities.
What is the formula for calculating the rate of change of length of shadow?
The formula for calculating the rate of change of length of shadow is: dS/dt = (h/d)(dh/dt), where S represents the length of the shadow, h represents the height of the object, and d represents the distance from the object to the light source.
What are the key factors that affect the rate of change of length of shadow?
The key factors that affect the rate of change of length of shadow are the height of the object, the distance from the object to the light source, and the changing position of the sun or light source.
How can I use related rates to solve real-world problems?
Related rates can be used to solve real-world problems by setting up an equation that represents the relationship between the changing quantities. By taking the derivative of this equation and plugging in the given values, you can solve for the unknown rate of change.
What are some common mistakes when solving related rates problems?
Some common mistakes when solving related rates problems include not properly identifying the changing quantities, not setting up the equation correctly, and not taking the derivative correctly. It is also important to carefully consider the units and make sure they are consistent throughout the problem.
11K
