Basic: Rule of Thumb for Newton's Cooling for ACs
  • Thread starter WWGD
  • Tags
    Cooling
In summary, if your AC goes down to around 61 degrees, it will take around an hour for the temperature to rise to an unacceptable level of 85 degrees.
WWGD
11,340
Hi, just curious:
Is there a nice rule-of-thumb to apply Newton's cooling to ACs? Specifically, if I know the AC temperature is , say 60 deg. , how long will it take, after I turn off the AC, before thetemperature rises to an unacceptable level of 85 degrees?
Thanks.
WWGD said:
rule-of-thumb
If your thumb feels warm, it's probably no longer 60 F. Practically, without knowing anything about thickness of insulation, or ambient temperature, you can say nothing.
Likes WWGD
Thanks, is there a formula/rule of thumb in function of those two variables?
(Area exposed to ambient temperature times temperature difference between ambient and system) divided by (thickness of insulation times heat capacity of system) in appropriate units.
Large, well insulated systems cool/warm slowly, and small, poorly insulated systems cool/warm quickly.
Are we talking about bait buckets or meat lockers?
Likes WWGD
Thanks, sort-of in-between . My AC goes down to around 61, I have your average apartment, 2nd floor. I think insulation is average. I will look it up, thanks.
Sunny side? Neighbors overhead?
Ah, sorry and thanks again. I have a small window facing sort-of inner garden, around 15' x 15' facing the north side, and it faces another building, i.e., there is a small garden separating my apartment from a 5-story building. No other windows I have 5 stories above me, one below, and and I don't get much direct sunlight. Strangely-enough, the place remained warm in Winter with little, if any heating, but the reverse is not so in Summer, the place is very humid and hot.
Neighbors below, behind, and to either side are elderly?
Likes WWGD
Ah, sorry again. Neighbors to the right, to the left, top and bottom, but not behind. I don't think are elderly, pretty sure not, but not 100% but how does that make a difference?
There is a tendency for older folks to run their living spaces slightly warmer. Just thought your AC might be having to fight someone's rheumatism.
Likes WWGD
I see. Thanks for your patience and sorry for my slowness. I will be out for a run for around an hour just in case.
FAQ: Basic: Rule of Thumb for Newton's Cooling for ACs
What is Newton's Cooling Law?
Newton's Cooling Law is a basic principle in thermodynamics that describes the rate at which an object cools down in a surrounding environment. It states that the rate of heat loss of an object is directly proportional to the difference in temperature between the object and its surroundings.
How does Newton's Cooling Law apply to ACs?
In the context of air conditioners, Newton's Cooling Law explains how the AC unit works to cool down a room. The AC unit removes heat from the room and transfers it to the outside environment, following the principle that heat will naturally flow from a higher temperature to a lower one.
What is the rule of thumb for Newton's Cooling Law for ACs?
The rule of thumb for Newton's Cooling Law for ACs is that for every 20 degree Fahrenheit difference between the indoor and outdoor temperature, the AC unit will cool the room by about 1 degree Fahrenheit.
How does the efficiency of an AC unit affect Newton's Cooling Law?
The efficiency of an AC unit does not affect Newton's Cooling Law, as it is based on the principle of heat transfer and not the specific technology used in the AC unit. However, a more efficient AC unit may be able to cool a room faster or maintain a lower temperature with less energy usage.
Are there any limitations to Newton's Cooling Law for ACs?
While Newton's Cooling Law is a useful principle for understanding the basic mechanics of AC units, it does have some limitations. It assumes ideal conditions and does not take into account factors such as humidity, airflow, and insulation, which can also affect the cooling process. Additionally, the rule of thumb may not be accurate for all AC units and may vary depending on the specific model and conditions.
