Basic topology - Limit points and closure
In summary: It seems like the best form of such a number would be of form 1/n, but... Do all rationals near zero have the form 1/n? This is what the example seems to be saying since we can pick any neighborhood, yet 0 is still a limit point.Yes, all rationals near zero have the form 1/n.
ran13
This isn't really hw, just me being confused over some examples.
I have 'learned' the basic definitions of neighborhood, limit point, closed, and closure but have some trouble accepting the following examples.
1. For Q in R, Q is not closed. The set of all limit points of Q is R, so its closure is R.
Between every two real numbers is a rational, I know as fact. But can't it be that between any two rational numbers is another rational?
- Since we can adjust the neighborhood of any rational to be of any radius, won't we cover all rational numbers in this way? So is it incorrect to say that the limit points of Q can be Q itself?
- Or is it simply a matter of being as complete as possible? Not complete in the real analysis sense, but in the sense that possibilities are included. It seems more complete to account for any point that can be a limit point of Q. In this case, I know it's correct to say more generally that R is the set of all possible limit points of Q, since Q is in R.
2. E = { 1/n | n = 1, 2, 3, ... }
The limit point of E in this case is 0, so the closure of E is E U {0}.
This is the set of rationals in (0,1] of the form 1/n. So 1 cannot be a limit point since we can chose the neighborhood of 1 to be, say 0.1, and it will not include any other points of E.
- Is this the same reasoning behind saying that no other 1/n in E can be a limit point? And the same reasoning behind saying that [0,1] in R is not the set of all limit points of E?
- But why then is zero a limit point? Can't we adjust its neighborhood so that it does not cover a number of the form 1/n? Are there no non-reducible rationals that are very close to zero that don't have the form 1/n, some tiny number over a large number?
It seems like the best form of such a number would be of form 1/n, but... Do all rationals near zero have the form 1/n? This is what the example seems to be saying since we can pick any neighborhood, yet 0 is still a limit point.Any clarity would be appreciated... Pardon my slowness but I want to know what mistakes I'm making here. Thanks :)
Correct.
Yes, if p and q are rational, then so is (p+q)/2, which is midway between p and q.
If you are asking whether every point of Q is a limit point of Q, the answer is yes.
Correct, every point of Q is a limit point of Q, but those are not the only limit points of Q. Every real number is a limit point of Q.
Correct.
Choose any neighborhood of zero with positive radius R > 0. No matter how small R is, you can find an N such that 1/N < R. Thus 0 is a limit point of the set.
No, but they don't have to have that form. The definition doesn't require that EVERY point of every neighborhood of zero is a point of the form 1/N. It just requires that every neighborhood of zero must contain at least one point of that form. An easy argument shows that this in fact means that each neighborhood of zero must contain infinitely many such points, but that is not the same as saying that all points in the neighborhood must be of that type.
jbunniii said:
Correct.
Correct.
Thank you for the help. I did get around to doing the proof that every neighborhood of zero contains infinitely many points in form 1/n, though it did take a while... Thanks again.
FAQ: Basic topology - Limit points and closure
What is a limit point in basic topology?
A limit point is a point in a topological space that can be approximated arbitrarily closely by points in the space. In other words, it is a point that is "near" other points in the space.
How do you determine if a point is a limit point?
A point x is a limit point of a set S if every open set containing x contains a point of S other than x itself. In other words, for any neighborhood of x, there is always at least one point in the set S that is also in that neighborhood.
What is the closure of a set in basic topology?
The closure of a set S in a topological space is defined as the smallest closed set that contains S. In other words, it is the set of all points that are either in S or are limit points of S. It can also be thought of as the set of all points that can be "reached" from S by taking limits.
Why is the concept of limit points important in basic topology?
The concept of limit points is important because it allows us to define important properties of topological spaces, such as compactness and connectedness. It also helps us understand the behavior of functions and sequences in these spaces.
What are some common examples of limit points in basic topology?
Some common examples of limit points include the set of real numbers, the set of rational numbers, and the set of irrational numbers. In these sets, every point is a limit point, since there are always other points in the set that can get arbitrarily close to any given point.
