Basicity of hydrides if group 15 elements
In summary: Basicity is determined by the number of available hydrogen atoms, while basicity is determined by the number of available oxygen atoms.In summary, Group V elements have more available hydrogen atoms than the other groups, and this affects their reducing properties.
AdityaDev
527
33
For group 15 elements the order of basicity given is
NH3 > PH3 > AsH3 > SbH3 > BiH3
And order of reducing strength is
BiH3 > sbH3 > AsH3 > PH3 > NH3
Why are they in opposite order? Reducing nature means tendency to donate electrons. Basicity means strength of bases and hence as basicity increases, the basic nature increases which means tendency to donate electrons increases. Then shouldn't they be in same order?
Chemistry news on Phys.org
Reducing agents do not "donate" electrons in a redox reaction; they lose electrons to oxidizing agents.
Fine. But still they lose electrons.
Lose, not loan. As bases they get them back, they are recoverable.
Ok. Now what about the order?
AdityaDev said:
order?
"I'll take a burger and fries, thank you."
You have to do some of the work. What do you know about the physical and electronic properties of Group V?
" do you want chicken burger or veg burger?"
Configuration ns2 np3
Half filled orbitals - more stabs than group 6
Nitrogen exists as N2 because of its ability to form p##\pi## - p##\pi## overlapping. Other g5 elements have less or no tendency for such bonds.
Phosphorous exits as white, red or black. White P is reactive.
(Other elements not in syllabus)
Nitrogen is a bit different because it lacks d orbitals.
NH3 is formed by haber's process or by thermal decomposition of NH4Cl (other anions are carbonate and sulphate).
PH3 is formed when White P4 reacts with NaOH or by reacting PH4I with KOH. PH3 can also be formed by reacting Ca3P2 with water or HCl.
Both ammonia and PH3 are basic.
Should I explain more?
Covering some of the chemistry works. How does the strength of the bond between hydrogen and the group V elements change as you move down the column?
Decreases
And, hydrogen is a fairly good reducing agent, is it not? And, if hydrogen is more easily released from a compound, it (the compound) is a stronger, or weaker reducing agent?
Reducing nature increases if hydrogen is released easily
Correct. Did you wish to look further at the "basicity" question?
What is the difference between basicity, basic strength and reducing nature?
So you say basicity is the removal of hydrogen?
I hate to use analogies; basicity/base strength is to reducing nature/strength as your eye color is to your shoe size --- knowledge of one tells you nothing about the other.
No. Hydrogen is a reducing agent. It is more freely available (more weakly bound) in BiH3 than in ammonia, and therefore BiH3 is the stronger reducing agent.
Ammonia is the smaller molecule, and the lone pair electrons are a more prominent feature of the molecule, and have no significant possibilities of being stabilized within the molecule by exchange (or jumping) around the additional d, and f orbitals that are at much lower energies in the heavier members of the family. They, therefore, can share ("donate") more strongly/easily with acidic species (H+, AlCl3, BH3).
As found in J.D.Lee's inorganic chemistry book
Related to Basicity of hydrides if group 15 elements
1. What is the basicity of hydrides of group 15 elements?
The basicity of hydrides of group 15 elements refers to the number of hydrogen atoms in the molecule that can be replaced by a base. In general, the basicity increases as we move down the group from nitrogen to bismuth, since the size of the atom increases and the bond strength between hydrogen and the element decreases.
2. How does the basicity of group 15 hydrides compare to other groups?
Group 15 hydrides have a lower basicity compared to group 16 and 17 hydrides. This is due to the larger size and lower electronegativity of the group 15 elements, which results in weaker H-X bonds and less acidic protons.
3. What is the relationship between basicity and acidity in group 15 hydrides?
As the basicity of group 15 hydrides increases, their acidity decreases. This is because a more basic molecule is less likely to donate its proton, making it less acidic. Additionally, as we move down the group, the electronegativity of the elements decreases, resulting in weaker H-X bonds and less acidic protons.
4. How does the basicity of group 15 hydrides affect their reactivity?
The basicity of group 15 hydrides directly affects their reactivity. As the basicity increases, the reactivity towards acids decreases, since a more basic molecule is less likely to donate its proton. However, the reactivity towards nucleophiles increases, as a more basic molecule is more likely to accept an electron pair.
5. What is the significance of basicity of group 15 hydrides in chemical reactions?
The basicity of group 15 hydrides is significant in determining the course and outcome of chemical reactions. It affects the acidity or basicity of the compounds involved, as well as their reactivity towards other molecules. Understanding the basicity of group 15 hydrides is important in predicting and controlling the behavior of these compounds in various chemical reactions.
  • STEM Academic Advising
  • Aerospace Engineering
  • Materials and Chemical Engineering
9K
  • Astronomy and Astrophysics
