MHB Bassman's question at Yahoo Answers regarding a solid of revolution
  • Thread starter Thread starter MarkFL
    Revolution Solid
The discussion revolves around a volume of rotation problem involving the function y=2-1/2x, bounded by y=0, x=1, and x=2, with rotation about the x-axis. The correct volume, as stated in the book, is 19pi/12. The solution involves using the disk method, where the volume of an arbitrary disk is expressed as dV=πr²dx, leading to the integral V=π/4∫(4-x)²dx from 1 to 2. After performing the integration and substitution, the final result confirms the book's answer. This demonstrates the application of calculus in determining the volume of solids of revolution.
MarkFL
MHB
Here is the question:
Calculus Volume of rotation question?
Hi, I am having difficulty with this volume of rotation problem
y=2-1/2x, y=0, x=1, x=2
The answer is 19pi/12 in the book but I when I try to solve the problem I cannot
work it out correctly. How would one go about working out this problem?
Thanks for you're helpAdditional Details:
I forgot to add that it is rotating about x-axis
I have posted a link there to this topic so the OP can see my work.
Mathematics news on Phys.org
Hello bassman,
The volume we are being asked to compute is that of the frustum of a cone, and the formula for such a solid is derived using the calculus here:
http://mathhelpboards.com/math-notes-49/volumes-pyramids-6131.html
$$V=\frac{\pi h}{3}\left(R^2+Rr+r^2 \right)$$
In this problem, we have:
$$h=1,\,R=\frac{3}{2},\,r=1$$
Hence:
$$V=\frac{\pi}{3}\left(\frac{9}{4}+\frac{3}{2}+1 \right)=\frac{\pi}{3}\left(\frac{19}{4} \right)=\frac{19\pi}{12}$$
Thus, we know the answer given by the book is correct. So, let's work this in the manner you are expected to use.
Let's use the disk method. The volume of an arbitrary disk is:
$$dV=\pi r^2\,dx$$
where:
$$r=y=2-\frac{1}{2}x=\frac{4-x}{2}$$
and so we have:
$$dV=\pi\left(\frac{4-x}{2} \right)^2\,dx=\frac{\pi}{4}(4-x)^2\,dx$$
Adding the disks by integrating, we may state:
$$V=\frac{\pi}{4}\int_1^2(4-x)^2\,dx$$
Using the substitution:
$$u=4-x\,\therefore\,du=-dx$$
we may state:
$$V=\frac{\pi}{4}\int_2^3 u^2\,du=\frac{\pi}{12}\left[u^3 \right]_2^3=\frac{\pi}{12}\left(3^3-2^3 \right)=\frac{19\pi}{12}$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
