[Bayes' Theorem] Finding the probability of guessing correctly
In summary: Also, the probability of drawing a white ball in each box is different. Therefore, the total number of white balls in each box and the total number of balls in each box should be taken into consideration.
LokLe
37
There are three boxes:
Box 1 contains one white ball and one black one.
Box 2 contains two white balls and one black one.
Box 3 contains three white balls and one black one.
Suppose I pick one box, then I pick a ball at random from this box and I show you the ball. Suppose the ball is white.
Which box would you guess it came from? What is your probability of guessing right?
P(H|E) = P(H)P(E|H)/P(E)
I calculated the probability of box 1/2/3 given white.
P(Box 1 | white)
= P(Box 1)*P(White | Box 1)/(P(Box 1)*P(White | Box 1) + P(Not Box 1)*P(White | Not Box 1))
= ((1/3)*(1/2)) / (((1/3)*(1/2) + (2/3)*(5/7)
= 7/27
P(Box 2 | white)
= P(Box 2)*P(White | Box 2)/(P(Box 2)*P(White | Box 2) + P(Not Box 2)*P(White | Not Box 2))
= ((1/3)*(2/3)) / ((1/3)*(2/3) + (2/3)*(4/6))
= 1/3
P(Box 3 | white) = P(Box 3)*P(White | Box 3)/(P(Box 3)*P(White | Box 3) + P(Not Box 3)*P(White | Not Box 3)) =
= ((1/3)*(3/4)) / ((1/3)*(3/4) + (2/3)*(3/5))
= 5/13
Therefore, you should guess box 3.
The probabilities summed up are not equal to 1. Is this normal or are there mistakes in my calculation?
Thank you!
There are mistakes in your calculation.
How do you compute P(white)?
I did not calculate P(white). Instead, I calculated P(Box (1/2/3) | white) + P(Not Box (1/2/3) | Not white)
P(white) = P (total number of white balls/total number of balls) = 6/9 = 2/3
Are all balls drawn with equal probability?
Likes FactChecker and PeroK
No. In box 3, the probability of drawing a white ball is higher = 3/4.
In other boxes:
P(box 1) = 1/2
P(box 2) = 2/3
In other boxes:
P(box 1) = 1/2
P(box 2) = 2/3
Not the probability of drawing a white ball, the probability of drawing any specific ball. For example, how do you compute P(white|not box 1)?
Likes LokLe
What happens on average if you repeat the process ##36## times? That should give you the probability of drawing each ball.
And, in fact, all the data you need.
Likes LokLe
So I drew a tree diagram and found P(White | Not box (1/2/3)).
P(White | Not box 1) = 1/3*2/3 + 1/3*3/4 = 17/36
P(White | Not box 2) = 1/3*1/2 + 1/3*3/4 = 15/36
P(White | Not box 3) = 1/3*1/2 + 1/3*2/3 = 14/36
So by using these values:
P(Box 1 | white) = P(Box 1)*P(White | Box 1)/(P(Box 1)*P(White | Box 1) + P(Not Box 1)*P(White | Not Box 1))
= (1/3*1/2) / (1/3*1/2 + 17/36)
= 6/23
P(Box 2 | white) = P(Box 2)*P(White | Box 2)/(P(Box 2)*P(White | Box 2) + P(Not Box 2)*P(White | Not Box 2))
= (1/3*2/3) / (1/3*2/3 + 15/36)
= 8/23
= (1/3*3/4) / (1/3*3/4 + 14/36)
= 9/23
The answer is box 3.
This should be the correct answer. Thank you all for the help!
From the 36 experiments:
Box 1 and white = 6
Box 2 and white = 8
Box 3 and white = 9
That gives you 23/36 as the probability of drawing a white ball. And the conditional probability of Box 1 given white as 6/23 etc.
Box 1 and white = 6
Box 2 and white = 8
Box 3 and white = 9
How did you calculate, for example, box 1 and white?
Oh It is 1/2*1/3 = 1/6 = 6/36.
Box 1 and white = 6
Box 2 and white = 8
Box 3 and white = 9
The main question is though: Do you understand why your original approach failed?
Edit: That was clearly intended to quote one of OP’s posts, not @PeroK ...
Likes PeroK
My original P(White | box (1/2/3)) is not correct since it is not just about calculating the number of white balls in other boxes. The whole case should be considered.
FAQ: [Bayes' Theorem] Finding the probability of guessing correctly
What is Bayes' Theorem?
Bayes' Theorem is a mathematical formula that helps us calculate the probability of an event occurring based on prior knowledge or information.
How does Bayes' Theorem work?
Bayes' Theorem uses conditional probability to calculate the likelihood of an event occurring based on prior knowledge or information. It takes into account both the prior probability of the event and the new evidence that may affect the probability.
What is the significance of Bayes' Theorem in science?
Bayes' Theorem is widely used in the field of science, especially in fields such as statistics, biology, and psychology. It allows scientists to update their beliefs and predictions based on new evidence, making it a valuable tool for decision making and analysis.
How is Bayes' Theorem used to find the probability of guessing correctly?
Bayes' Theorem can be used to calculate the probability of guessing correctly by taking into account the prior probability of the event (e.g. the probability of guessing correctly by chance) and the new evidence (e.g. the accuracy of a test or the knowledge of the person making the guess). This allows us to make more accurate predictions and decisions.
Can Bayes' Theorem be used in real-life situations?
Yes, Bayes' Theorem can be applied to various real-life situations, such as predicting the outcome of medical tests, analyzing the effectiveness of marketing strategies, and making investment decisions. It is a powerful tool for making informed decisions based on both prior knowledge and new evidence.
