MHB Bayes' theorem problem, Struggling with this the whole night, .Thank you.
  • Thread starter Thread starter hildanhk
    Thank you Theorem
The discussion revolves around applying Bayes' theorem to determine the probabilities of a good or poor economy based on predictions from an economic study. Initially, the probabilities are set at 60% for a good economy and 40% for a poor economy, with the study's accuracy rates provided. A participant struggles with calculations, mistakenly using incorrect values in the formula, leading to an incorrect result of 0.51 instead of the correct 0.923 for the probability of a good economy given a prediction of good. Clarifications are offered regarding the correct interpretation of the probabilities and the formula application. The conversation emphasizes the importance of accurately applying Bayes' theorem to derive the correct posterior probabilities.
hildanhk
Two states of nature exist for a particular situation: a good economy and a poor economy. An economic study may be performed to obtain more information about which of these will actually occur in the coming year. The study may forecast either a good economy or a poor economy. Currently there is 60% chance that the economy will be good and a 40% chance that the economy will be poor. In the past, whenever the economy was good, the economic study predicted it would be good 80% of the time. (The other 20% of the time the prediction was wrong.) In the past, whenever the economy was poor, the economic study predicted it would be 90% of the time.(The other 10% of the time the prediction was wrong.)
a) Use Bayes' theorem and find the following:
P(good economy| prediction of good economy)
P(poor economy| prediction of good economy)
P(good economy| prediction of poor economy)
P(poor economy| prediction of poor economy)
b) Suppose the initial (prior) probability of a good economy is 70% (instead of 60%), and the probability of a poor economy is 30% (instead of 40%). Find the posterior probabilities in part a based on these new values.
Mathematics news on Phys.org
Hi hildanhk,
Can you show us what you have tried so our helpers can see where you are stuck and can then offer help?:)
I am try to use the formula and plug the numbers in. But I could not get the correct answers.
P(A|B)= P(B|A)P(A)/P(B|A)P(A)+P(B|A')P(A')
For example, I put
P(good economy| prediction of good economy)= 0.8*0.6/0.8*0.6+0.9*0.6= 0.51
But the answer should be 0.923
For example, I put
Welcome to MHB, hildanhk! :)
You seem to have mixed up the last part (0.9 * 0.6).
EDIT: The phrasing is somewhat confusing.
We have P(predict good | good) = 80%.
The remainder is P(predict poor | good) = 20%
And from P(predict poor | poor) = 90%,
we get that P(predict good | poor) = 10%.
So it should be (edited):
$$P(B|A')\ P(A') = P(\text{predict good}|\text{poor})\ P(\text{poor}) = 0.1 \cdot 0.4$$
So you should have:
$$P(\text{good}|\text{predict good}) = \frac{0.8 \cdot 0.6}{0.8 \cdot 0.6 + 0.1 \cdot 0.4} \approx 0.923$$
I have updated my previous post, since I made a mistake with my interpretation of the wording in the problem statement.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
