Bayesian method vs.maximum likelihood
In summary, the discussion touches on the differences between Maximum Likelihood Estimation (MLE) and Bayesian probability in terms of their frameworks and approaches to statistical inference. The priority of using MAP or ML depends on one's mindset and there are various heuristics and comparisons between the two methods.
Mark J.
81
Hi,
Wondering if there is any priorities one method has versus the other one and are there any specific cases where to use one vs.other?
regards
Hey Mark J.
I'm not exactly sure what you mean specifically. The MLE is part of a massive framework used in point and interval estimation for statistical inference, but the bayesian stuff is a framework dealing with generalizing probabilistic situations where parameters of distributions are not constant (which leads to all kinds of other results both probabilistically and statistically).
Do you have a specific example of Bayesian Probability or Inference that you are referring to?
For example if you are talking about inference, are you talking about estimating parameters with a specific posterior and prior? Specific posterior and general prior? General posteriors and priors?
The priority of MAP vs ML depends largely on whether one is already of a Bayesianist or frequentist mindset. Maximum a posteriori and maximum likelihood have their own lingo, their own sets of a massive underlying frameworks, their own set of heuristics for overcoming weaknesses in the methods. I've seen a few papers that compare MAP vs ML. However, if you look at the publications of the authors of such a paper before reading it, you can form a pretty solid prior regarding which technique will come out on top.
Related to Bayesian method vs.maximum likelihood
1. What is the difference between the Bayesian method and maximum likelihood?
The main difference between the Bayesian method and maximum likelihood is their approach to estimating the parameters of a statistical model. Maximum likelihood focuses on finding the parameters that make the observed data most likely, while the Bayesian method incorporates prior knowledge or beliefs about the parameters into the analysis.
2. Which method is better for parameter estimation?
There is no clear answer to which method is better for parameter estimation, as it ultimately depends on the specific situation and goals of the analysis. Maximum likelihood is often used when there is little prior information available, while the Bayesian method can be more useful when there is prior knowledge or when making predictions.
3. How does the Bayesian method account for uncertainty?
The Bayesian method accounts for uncertainty by using prior distributions, which represent our beliefs about the parameters before seeing the data. After incorporating the data, the prior distributions are updated to posterior distributions, which represent our beliefs about the parameters after seeing the data. This allows for a more nuanced understanding of uncertainty compared to maximum likelihood, which only provides point estimates.
4. Can the Bayesian method and maximum likelihood be used together?
Yes, the Bayesian method and maximum likelihood can be used together in a technique called Bayesian model averaging. This approach combines the results from multiple models, each using either the Bayesian method or maximum likelihood, in order to incorporate uncertainty and potentially improve the overall estimation.
5. Are there any assumptions or limitations of these methods?
Both the Bayesian method and maximum likelihood have assumptions and limitations. Maximum likelihood assumes that the data is independent and identically distributed, and can be sensitive to outliers. The Bayesian method requires the specification of prior distributions, which can be subjective and may affect the results. Additionally, both methods may not be appropriate for complex models with a large number of parameters.
