BCS theory by canonical transformation
In summary, Tinkham derives the BCS theory by canonical transformation and explains that the characteristic BCS pair interaction Hamiltonian leads to a ground state which is a phase-coherent superposition of many-body states with pairs of Bloch states $(k\uparrow, -k\downarrow)$ either occupied or unoccupied. This phase coherence allows operators such as $c_{-k\downarrow}c_{k\uparrow}$ to have nonzero expectation values, unlike in a normal metal where the phases are random. The reduced Hamiltonian is used to describe this pairing of electrons with opposite momentum. The concept of Off-Diagonal Long Range Order (ODLRO) is also important in characterizing the superconducting state.
IFNT
31
I am reading Tinkham's "introduction to superconductivity" 1975 by McGraw-Hill, Inc.
Tinkham derives the BCS theory by canonical transformation. At the beginning of the chapter he writes:
"We start with the observation that the characteristic BCS pair interaction Hamiltonian will lead to a ground state which is some phase-coherent superposition of many-body states with pairs of Bloch states $(k\uparrow, -k\downarrow)$ occupied or unoccupied as units. Because of the coherence, operators such as $c_{-k\downarrow}c_{k\uparrow}$ can have nonzero expectation values b_k in such a state, rather than averaging to zero as in a normal metal, where the phases are random. "
I have some questions:
1. Is the characteristic BCS pair interaction Hamiltonian the so-called "reduced Hamiltonian"?
2. The BCS ground state is a state with pairs of Bloch states $(k\uparrow, -k\downarrow)$ either occupied or unoccupied, but what does the phase-coherence mean?
3. Why does it follow from coherence, that operators such as $c_{-k\downarrow}c_{k\uparrow}$ can have nonzero expectation values? When he writes phase, he means the phase of what?
It is the first time posting here, so bear with me.^^
Have I done something wrong regarding my post?
Does anyone know BCS theory?
Hi IFNT, welcome to the forum.
I think most textbooks are a little vague on the subject and I am not sure I have a consistent picture of this stuff myself. However I can try to explain what I think Tinkham refers to.
1. Not sure what reduced Hamiltonian means in this context. Could you give us the page number where this term is used?
2. Phase coherence means that the phase [itex]\varphi[/itex] as in Eq. (3.18a) in the BCS ground state is well defined, i.e. has a certain value.
3. If the phase in the BCS ground state is not well defined, i.e. you have a superposition of all possible phases as in Eq. (3.18b) you have a number conserving state. For a number conserving state the average of [itex]b_k[/itex] will necessarily be zero. You can try to evaluate the average w.r.t. the ground state in Eq. (3.18b) directly and you will find that the integration over phase causes the expectation value to "average out".
Basically a well defined phase in a superconductor is similar to having a well defined direction of spin in a ferromagnet. In the symmetry conserving state an evaluation of [itex]\langle\vec{S}\rangle[/itex] will average out since there is no preferred direction of the spin. In the symmetry broken phase a particular direction of spin (or value of the phase in a superconductor) is chosen arbitrarily.
I should note that the vanishing of the expectation value [itex]\langle b_k\rangle[/itex] does not necessarily imply that there is no superconducting order. A more general way to characterize the superconducting state is through the concept of Off-Diagonal Long Range Order (ODLRO).
Hope this helps somewhat.
Dear IFNT,
jensa answered most of your questions better than I could, hence I only want to comment on your question 1. The BCS hamiltonian contains a term in which electrons with momentum k and k' are annihilated and electrons with k+q and k'-q are generated. The reduced hamiltonian retains only the terms with k'=-k. This corresponds to working in the subspace with electrons with k and -k being paired as stated in Tinkham. The use of this hamiltonian is believed to lead to the correct expression for e.g. the ground state energy, but obviously there is no possibility to describe e.g. states carrying a current where k' not equal -k.
Jensa, thank you for the reply. I don't know what book you are referring to, as there are no (3.18a) and (3.18b) in my book and the BCS ground state is first giving in (2-14).
I have also trouble understanding the concept of diagonalizing a Hamiltonian. In the book he uses Bogoliubov transformation to change basis, then he says that the Hamiltonian is diagonalized when it only contains terms proportional to [itex]\gamma_{k0}^{\dagger}\gamma_{k0}[/itex] and [itex]\gamma_{k1}^{\dagger}\gamma_{k1}[/itex].
Do you know why that is so?
The gamma operators fulfill the usual relations for fermion anihilation operators. Hence the ground state fulfills e.g. gamma |0>=0 and excited states can be obtained by operating on |0> with the adjoints of gamma (the particle creation operators). The hamiltonian is diagonal in the basis spanned by these operators as [tex] \gamma_k^+ \gamma_k[/tex] is the number operator which counts the number of excitations of momentum k (0 or 1). Compare also the formalism of creation and anihilation operators for a harmonic oscillator and for a gas of free fermions.
Dear DrDu,
Thank you for the reply. I have found a site, http://jila.colorado.edu/pubs/thesis/milstein/appB.pdf , where the Bogoliubov Transformation is explained somewhat short and I am trying to understand it right now. I think I have trouble understanding the whole setup.
Changing basis, but what vector space are the creation and annihilation operators basis to?
I can conclude from this that the excited states are eigenstates of the hamiltonian. How do I come from this to the fact that the Hamiltonian is diagonal?
Best regard, IFNT
To your second question: If you know the eigenstates of the Hamiltonian then the Hamiltonian is diagnoal in the basis of these eigenstates.
Okay, but don't you have to know that the eigenstates span the space? If so, what space are we talking about? Is it the Fock space? Is it infinite dimensional?
I am still on my bachelor degree so I am unclear about a lot of stuff.
Well, the gound state is characterized by [tex] \gamma_{..} | 0 \rangle =0 [/tex]. This yields the BCS ground state wavefunction.
The excited states spanned by operating will all possible combinations of the creation operators gamma spans an infinitely dimensional Fock space. Note that there is not only one Fock space but an infinity of them. Especially, the one we are considering here is different from the Fock space of free Fermions. And, as in the case of free Fermions, for any electron density there is another Fock space.
Thanks a lot for your replies DrDu, I imagine that Linear algebra in a infinite dimensional space is similar to finite dimensional space.
One last question, if you got the time:
Why do we want to make operators diagonal? It is easy to find the eigenvalues, but is that all?
...yes, and not to forget the eigenvalues.
I cannot see what equations you are referring to. If we have the BCS wavefunction, does this mean that the phase between the two electrons in one single cooper pair is fixed, but the phase between two cooper pairs are arbitrary?
Sorry for not answering for a while. I've been on vacation and didn't check the forum. The equations I refer to are in Tinkhams second edition, I suppose you have the first one. You can probably find the equations using google books or the preview feature at amazon. If not, let me know and I''ll write them for you.
The phase in a superconductor is intimately related to the number of cooper pairs. More precisely the number of cooper pairs and the phase are conjugate variables. The phase that is referred to is the relative phase between two many particle states with [itex]N[/itex] and [itex]N+1[/itex] number of cooper pairs. To be phase coherent it is important that this phase is well defined (does not fluctuate). This in turn means that the number of electron pairs in your system will not be well defined (fluctuates). Inversely, if the number of electrons is well defined then the phase will not be well defined.
Thanks for replying Jensa, I did my last post only a couple hours before you replied so thank you for replying so fast.^^
The Tinkham book doesn't have a preview feature on Amazon and google books shows only to page 30 and BCS theory starts at page 43 I think. It would be great appreciated if you could write the equations for me.
""The phase that is referred to is the relative phase between two many particle states with [itex]N[/itex] and [itex]N+1[/itex] number of cooper pairs. To be phase coherent it is important that this phase is well defined (does not fluctuate).""
How do I see that this phase is well defined? Can I see it from the BCS ground state wavefunction? Why is this phace coherence so important?
And if one of the most important things about a superconducter is its phasecoherent wavefunction then how can we derive so many results from it? I mean, in a real physical problem isn't the particle number is always well defined?
Sure.
Eq. (3.18a)
[tex]
|\psi_\varphi\rangle=\Pi_k(|u_k|+|v_k|e^{i\varphi}c_{k\uparrow}^*c_{-k\downarrow}^*)|\phi_0\rangle
[/tex]
Eq. (3.18b)
[tex]
|\psi_N\rangle=\int_0^{2\pi}d\varphi e^{-iN\varphi/2}\Pi_k(|u_k|+|v_k|e^{i\varphi}c_{k\uparrow}^*c_{-k\downarrow}^*)|\phi_0\rangle = \int_{0}^{2\pi} d\varphi e^{-iN\varphi/2}|\psi_\varphi\rangle
[/tex]
Yes, in Eq. (3.18a) above you see that there is a fixed (and constant) phase [itex]\varphi[/itex]. It is assumed to be arbitrary but the same everywhere in the superconductor.
You may think of the analogy with the spin orientation in ferromagnets, if the spin orientation at different sites (different positions) are oriented randomly without any relation to their neighbours, you do no not have a ferromagnet. However, if all spins are oriented in the same (random) direction, you do have a ferromagnet.
In Eq. (3.18a) the choice of the phase is random, but it is the same for any state [itex](k\uparrow,-k\downarrow)[/itex]. If you were to let the phase depend on the state [itex]\varphi\rightarrow \varphi_k[/itex], where each [itex]\varphi_k[/itex] were random without any relation to each other, you would not have a superconductor.
These are excellent questions. Ironically, the two people who are trying to help you (me and DrDu) have both asked related questions on this very forum :) So you see, I am probably not the most qualified person to answer this. Maybe DrDu has gained some knowledge that he could share.
I would just like to point out the following things:
1) The BCS wave function is an approximate ground state. This approximation becomes exact (I think) in the limit of infinitely many particles (and infinitely large volume), at which point the fact that it does not conserve number of particles becomes negligible.
The fact that we need to resort to the limit of infinitely many particles/infinite volume is a general feature in descriptions of phase transitions and spontaneously broken symmetries.
2) In contrast to, say the global spin orientation in ferromagnets, the global phase of the superconductor is itself not an observable quantity. Any observables are represented by number conserving operators and thus the global phase will never enter any expectation values of such observables. This also suggests that the fact that the BCS ground state is a superposition of different particle states is not really the crucial aspect of the wave function.
Note: Somehow my post looks completely messed up when I preview it, so I hope it comes out correctly.
In some old article P. W. Anderson ( have to find the citation at home) notes that the BCS ground state which does not conserve particle number obviously also means that we are dealing with a superposition of states with different charge. These states thus will decohere extremely rapidly. To show this, one only has to calculate the difference in electrostatic energy between states differing in charge by one. However, he also shows that this effect won't limit the observability of the Josephson effect.
Thank you so much for this thorough reply Jensa!
As I understand it, the phase is the same for every cooperpair [itex](k\uparrow,-k\downarrow)[/tex]. Is this phase the same as the relative phase between two many particle states with [tex] N[/tex] and [itex]N+1[/itex] number of cooper pairs, the relative phase between [tex]u_k[/tex] and [tex] v_k[/tex]?
Forget my last post, it made no sense.
I have one last question: the BCS ground state is phase coherent, and there exist an energi gap, why does this make the material superconducting?
When I apply an E-field to the sample for a short period, the cooper pairs are accelerated and changes momentum per pair from [tex]\vec{k}=0[/itex] to [tex]\vec{k'} \noteq 0[/itex]. Only a scattering processes where a cooper pair splits up into two individual electrons will results in the delay of the current. This is only possible when the kinetic energy of the pair is higher than the energy gap, thus we have the critical current density. Where does the phasecoherence come into the picture?
Well, in quantum mechanics it is not sufficient that there is an energy gap to guarantee the vanishing of the current. After all you don't have to excite the pair completely to get a current
but it is sufficient to create a superposition containing just a little bit of an excited pair with momentum k. For sufficiently small perturbing fields, the admixture of the excited states can be calculated in second order of perturbation theory. The energy gap guarantees that the denominator remains finite. Coherence of the wavefunction yields the result that the numerator vanishes in the limit of k to 0. This is known as the stiffness of the wavefunction, an idea going back to the Londons in the early days of superconductivity. This is nicely explained in Ch. Kittel, Quantum theory of solids, my absolute favorite on the theory of superconductivity.
There exists an alternative explanation by Stephen Weinberg in Quantum theory of fields, vol. II which rests on the fact that a superconductor is a system with spontaneously broken symmetry. The argument can be understood without knowledge of the rest of the books.
Thank you for the reply DrDu.
But oh my, I don't have the necessary time nor will to lend the books and read them. My paper has already exceeded its maximum page number so I will not add more stuff to it. It just seems to me that the writing the paper on superconductivity without explaining the zero resistance is a bit insufficient. Thanks for the recommendations though, I will read them at some point. Is there any intuitive way to explain this at all?
Come to think of it, the excited states should not be superconducting? E.g. one excited state could be [tex]\gamma_{k1}^\dagger |\Phi_G>[/tex], here there is a single electron that is not bound in a pair.
Related to BCS theory by canonical transformation
1. What is the BCS theory by canonical transformation?
The BCS theory by canonical transformation is a theoretical framework in condensed matter physics that describes the behavior of superconductors. It was proposed by John Bardeen, Leon Cooper, and John Schrieffer in 1957 and is based on the concept of Cooper pairs, which are pairs of electrons that interact via an attractive force due to lattice vibrations.
2. How does the BCS theory explain superconductivity?
The BCS theory explains superconductivity by proposing that at low temperatures, electrons form Cooper pairs and flow through the lattice without any resistance. This is due to the attractive force between the electrons, which overcomes the repulsive force between them. This leads to the phenomenon of zero electrical resistance and perfect conductivity.
3. What is the role of canonical transformation in the BCS theory?
Canonical transformation is a mathematical tool used in the BCS theory to simplify the Hamiltonian of a superconductor. By transforming the Hamiltonian, it is possible to separate the interactions between electrons from the kinetic energy term, making it easier to solve the equations and understand the behavior of the system.
4. How does the BCS theory explain the energy gap in superconductors?
The BCS theory explains the energy gap in superconductors as the energy required to break a Cooper pair. At low temperatures, the electrons form these pairs and have a lower energy compared to when they are unpaired. This energy difference creates a gap in the energy spectrum, which is responsible for the zero resistance and perfect conductivity observed in superconductors.
5. What are some of the limitations of the BCS theory by canonical transformation?
While the BCS theory by canonical transformation is a successful model for understanding superconductivity, it has some limitations. It cannot explain high-temperature superconductivity, which occurs at temperatures above 30 K. Additionally, it does not take into account the effects of impurities, magnetic fields, or the presence of defects in the material, which can affect the behavior of superconductors.
  • Atomic and Condensed Matter
  • Quantum Interpretations and Foundations
11K
  • Quantum Physics
  • Classical Physics
