Bead attached to a spring and moving along a horizontal wire
In summary, the book's solution appears to be correct, but I'm willing to be convinced that the book is wrong.
beowulf.geata
I'm self-studying an introductory book on mathematical methods and models and came across the following problem:
1. A bead of mass m is threaded onto a frictionless horizontal wire. The bead is attached to a model spring of stiffness k and natural length l0, whose other end is fixed to a point A at a vertical distance h from the wire (where h > l0). The position x of the bead is measured from the point on the wire closest to A. Find the potential energy function U(x).
I'm rather puzzled by the solution given in the book, which claims that since the length of the spring is (h2+x2)1/2 and its extension is (h2+x2)1/2 - l0, then U(x) = (1/2)k((h2+x2)1/2 - l0)2.
I think that's incorrect because only the x-component of the force exerted by the spring on the bead is relevant to the calculation of U(x). The x-component is -k(l-l0)cos[itex]\theta[/itex], where l = (h2+x2)1/2 and cos[itex]\theta[/itex] = x/(h2+x2)1/2. Hence, U(x) is -[itex]\int[/itex](-kx + kl0x/(h2+x2)1/2)dx. Is this correct?
Humm. Interesting question. I'm not sure I can answer it. At first thought you are correct, but then ...
With the spring stretched the energy stored in the spring will be that calculated in the book. What happens to the energy when the spring is released? Where does it go if you apply conservation of energy? The wire is frictionless so as far as I can see all the energy ends up in the bead (eg not some fraction of that due to the Cosθ issue you raise).
So I conclude the book is correct but I'm willing to be convinced you are right and the book is wrong.
See if you can show that both expressions are correct, although they might differ by an additive constant.
The integral should evaluate to
kx2/2 - kl0(h2 + x2)1/2 + C.
Hence, the difference between my solution and the book's is:
kx2/2 - kl0(h2 + x2)1/2 + C - (k(h2 + x2)1/2l0 + (1/2)kh2 + (1/2)kx2 - (1/2)kl02)
= C - (1/2)kh2 + (1/2)kl02,
so the two solutions do appear to differ by a constant...
I would like to clarify that both solutions presented in the book and your attempt at a solution are correct, but they are solving for different potentials. The solution in the book is finding the potential energy function U(x) for the entire system, including the potential energy stored in the spring and the gravitational potential energy due to the vertical distance h. This is why the length of the spring and its extension are taken into account in the calculation.
On the other hand, your solution is finding the potential energy function U(x) solely for the spring, without considering the gravitational potential energy. This is a valid approach, but it will result in a different potential energy function.
Both solutions are correct depending on the context and what potential energy is being considered. As a scientist, it is important to understand the assumptions and context of a problem in order to choose the appropriate approach and solution.
FAQ: Bead attached to a spring and moving along a horizontal wire
What is the purpose of the bead attached to a spring moving along a horizontal wire?
The purpose of this experiment is to study the motion of an object attached to a spring and moving along a horizontal wire. This setup allows us to observe the relationship between force, displacement, and velocity of the object.
How does the spring affect the motion of the bead?
The spring provides a restoring force that opposes the motion of the bead. As the bead moves away from its equilibrium position, the spring exerts a force in the opposite direction, causing the bead to oscillate back and forth.
What factors can affect the motion of the bead?
The motion of the bead can be affected by several factors, including the mass of the bead, the stiffness of the spring, and the amplitude and frequency of the oscillations. Friction and air resistance can also play a role in the motion of the bead.
What is the relationship between the force applied to the spring and the displacement of the bead?
According to Hooke's Law, the force applied to the spring is directly proportional to the displacement of the bead. This means that as the bead moves further away from its equilibrium position, the force exerted by the spring increases proportionally.
How can the motion of the bead be used to determine the spring constant?
The period of oscillation of the bead is directly related to the spring constant. By measuring the period and using the equation T = 2π√(m/k), where T is the period, m is the mass of the bead, and k is the spring constant, we can determine the spring constant of the spring used in the experiment.
